10-09-2013, 11:38 AM | #1 |
Spring Replacement on a 34 4dr sedan
I have a 34 sedan and need a rear spring replacement , can the "Barn" tell me what years on these old Fords would be a good replacement, and how many leaves ,previous owner has taken some leaves out to lower the car, but it bottoms out on small road bumps not good , thanks ...
10-09-2013, 12:01 PM | #2 |
Re: Spring Replacement on a 34 4dr sedan
'32-'34 springs are curved. All the other Fords have straight leaves. DD
10-10-2013, 01:12 PM | #3 |
Thanks for the info, v8 coopman , now I can go looking , ..
10-10-2013, 03:57 PM | #4 |
11 or 12 leaves and curved as mentioned, Eaton detroit makes new ones but pricey because of the curve, I bought a front and rear set from them. My original tudor had 12 leaves at rear but i opted for 11 from detroit wich I think is most common. There is another thread that talks about this in more depth, the number of leaves depended on the model, obviously a sedan delivery might have the most and a coupe less etc. KEN
10-10-2013, 10:01 PM | #5 |
Here is an old thread about 32 springs, that also talks about 33-34 springs as well. Check out post #16 and some of the other posts by DavidG. Keep V-ing and 4-banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
