03-29-2021, 04:11 PM | #1 |
41 pickup grill/splash pan
Hi All,
I have a question for you 39 Delux ,40 standard and 40 41 pickup owners. My lower grill pan is a full inch higher then my splash/radiator pan. They are both in vary nice original condition nothing bent or smashed they just don't connect like I think they should. What am I not seeing? Is there a filler piece I'm missing? The bolt holes line up but there is a full inch in between of nothing. Thanks Tim Last edited by pistonbroke; 03-29-2021 at 04:27 PM. |
03-30-2021, 08:05 AM | #2 |
Re: 41 pickup grill/splash pan
My originals were pretty rough and rusty so both of them are repops. They were within 3/16 of each other.
Sorry I can't help much. |
03-30-2021, 08:50 AM | #3 |
HD Rider, Can you show pictures or are you picture challenged like me. I need to find a eight year old teach me. Thanks for the reply, Tim
03-30-2021, 02:44 PM | #4 |
It'll be late tonight before I get home from work.
03-31-2021, 07:35 AM | #5 |
Here you go.
The radiator mounts on top of the frame. The splash pan mounts under the flange on the frame. Let me know if you want any other pics. |
03-31-2021, 08:17 AM | #6 |
I will go compare to what I have this afternoon. I found out my lower grill pan is for the six cylinder as is my hood and latch , so that may be why the V8 radiator pan doesn't line up. The telltale is the grill pan has a factory stamped hole for the radiator drain cock . Thanks again , Tim |
03-31-2021, 10:38 AM | #7 |
I remember when I built the blue 41, the pan under the radiator did stick down like yours. I called my friend that owns the black 41 I show in the picture. His is original and it does stick down just like yours. Good luck
03-31-2021, 01:20 PM | #8 |
Her is a picture of our 40. You can see the radiator pan corners .
