01-07-2021, 12:40 PM | #1 |
Wood top ribs question
I installed the wood rib kit from classic wood products and it fit perfectly in my 1936 Fordor. I got new chicken wire from tractor supply and I am ready to install it but I noticed the factory ribs have thin pieces of cardboard between the ribs and chicken wire. Do I need the cardboard pieces and if so where do I buy them? Or do I just staple the chicken wire directly to the ribs?
01-07-2021, 03:59 PM | #2 |
Re: Wood top ribs question
On the ribs that I have the insulating material is either a waterproof cardboard or a thick tar paper type material. There also was little evidence that the chicken wire was stapled to the ribs. Maybe in one or two places??
01-07-2021, 08:41 PM | #3 |
Was the wire ever used as antenna? Newc
01-07-2021, 09:24 PM | #4 |
On all closed 35-36 Fords the chicken wire was the antenna. Thats why the chicken wire must stay isolated from the metal body
01-07-2021, 11:48 PM | #5 |
Yes my car has an antenna wire hooked to the original chicken wire
03-12-2021, 12:22 PM | #6 |
03-12-2021, 09:13 PM | #7 |
Nice work! I also have a 36 Ford sedan. Terry
03-13-2021, 11:57 AM | #8 |
Do not install the chicken wire over bare wood. Place a strip of denim or muslin on the top of each rib. This prevents the chicken wire from squeaking or tapping on the wood while driving.
03-14-2021, 08:59 PM | #9 |
On a 36/5 window is there chicken wire on across the wood ribs also? My car came with no roof just the wood slats. How wide and how long would it be? To attach the ant wire I assume the center wire would be soldered to the mesh but what about the coax braid outer?
03-15-2021, 10:23 AM | #10 |
I'm assuming that all the closed cars for 36 had the chicken wire. And over the wire there was a thin padding material before the long grained top fabric goes on. I'm getting this from the 35-36 Ford book and it will come in handy for your restoration project. Maybe Don will offer more info. He's the author of the book I mentioned. Terry
03-15-2021, 05:45 PM | #11 |
The inside antenna wire does solder to the chicken wire and must be isolated from steel that could ground it.
The antenna wire coax does have a tab near the antenna wire connection from the radio. That tab is grounded the the dash screw on the driver side. |
