Old 03-08-2021, 10:02 AM   #21
JSeery
JSeery's Avatar
Default Re: Installing 95% oil filter system issue
I think the clearance issue is going to depend on a lot of factors that can very between installations. You just about going to have to figure it out as you go. Might consider a trial fitting with a separate piece of tubing before you start binding the one you intend to use.
Old 03-08-2021, 12:22 PM   #22
Bored&Stroked
Bored&Stroked's Avatar
If you are worried about clearance with your headers, then you can put an 1/8" NPT 90 degree male-to-female elbow into the block, then the adapter from 1/8" NPT to 1/4" compression/flare. This should enable you to keep the line close to the block and away from the headers. Now, you may have to make or modify your own lines - but that isn't a big deal.
Best of luck on getting your new engine done and on the road!
B&S
Old 03-10-2021, 12:16 PM   #23
AnthonyG
AnthonyG's Avatar
Couldn’t find the right adapter at hardware store. Found the 1/4”-1/8” pipe thread adapter but couldn’t find the one with the nipple on the inside that the tube flare needs. What’s it called? Thinking the ones I found that were similar but w/o a nipple were NPT.
Nomad
AnthonyG is offline   Reply With Quote
Old 03-10-2021, 01:19 PM   #24
cas3
its a flare fitting. auto store should have it, common on vacuum lines, brake lines etc
Old 03-10-2021, 01:24 PM   #25
marko39
Is there any reason a compression fitting can't be used, less trouble to work with?
marko39 is offline   Reply With Quote
Old 03-11-2021, 07:36 AM   #26
dan35
this is all going to help when I do mine, thanks!
dan35 is offline   Reply With Quote
Old 03-11-2021, 08:15 AM   #27
Bored&Stroked
I'd go to a NAPA store or maybe Jegs or Summit Racing - they have extensive catalogs of fittings.
When it comes to flare fittings - you need to know which flare type - there are three. It is most likely that you're looking for a 45 degree angle SAE type flare. Don't make the mistake of buying an aircraft flare 'AN' of 37 degrees.
Old 03-11-2021, 09:17 AM   #28
AnthonyG
AnthonyG's Avatar
I discovered the correct fittings were on the filter I got. There’s 2, the one at the top is a 90 degree, the one at the bottom is strait. Just to get the motor in I took the 1 off the bottom & used on the return treaded hole on the block. Good for now. I think the correct designation for the fitting is npsm 1/8” male-npt 1/4” female, adapter.
Nomad
Old 03-11-2021, 11:10 AM   #29
51 MERC-CT
51 MERC-CT's Avatar
Actually (1/8 male NPT- 1/4 Female inverted flare )
Old 03-11-2021, 01:30 PM   #30
Ken hash
Ken hash's Avatar
Here are the instructions I used on my flatheads. Now I still have oil pressure at an idle.
File Type: jpg 5767A5F4-274B-439E-8AAB-11DDA6039FE0.jpg (61.5 KB, 24 views)
File Type: jpg 9E0C74CF-1050-427E-A1A0-C52C7A251CE9.jpg (71.3 KB, 19 views)
Ken hash is offline   Reply With Quote
Old 03-11-2021, 02:03 PM   #31
AnthonyG
AnthonyG's Avatar
Got it & thx again! 51 Merc-Ct SleezeBay had
File Type: jpg 573D036F-E3B9-4840-99E4-80FA9991E255.jpg (20.3 KB, 14 views)
Nomad
Old 03-11-2021, 02:20 PM   #32
Ken hash
Ken hash's Avatar
These are the instructions I used on my engine. Now there is oil pressure at an idle.
File Type: jpg 37A75C71-B6A6-48E6-B210-E082174DC77F.jpg (61.5 KB, 12 views)
File Type: jpg 877DFB82-1E41-4891-B616-4243852FAF45.jpg (71.3 KB, 12 views)
Old 03-11-2021, 02:41 PM   #33
FlatheadTed
FlatheadTed's Avatar
Thats a good one Ken ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
