Old 06-09-2018, 08:01 PM   #1
RAYSSUPERDELUX
Default Engine start
Hi gents-
I've just installed a flathead and drive train in my '48 frame. What
minimum temporary wiring do I need to start this thing?
RAYSSUPERDELUX is offline   Reply With Quote
Old 06-09-2018, 09:18 PM   #2
flatjack9
flatjack9's Avatar
Default Re: Engine start
Starter solenoid and the wiring to power it and voltage to the coil.
Old 06-09-2018, 09:33 PM   #3
leon bee
Yep, mine's still like that. Big fat, (stiff) 2/0 wire from electric supply house on battery, new push button solenoid from NAPA, a few extra grounds scattered around and a hot wire to the coil.
leon bee is offline   Reply With Quote
Old 06-09-2018, 09:38 PM   #4
JSeery
JSeery's Avatar
Depending on the coil you are using I would include a ballast resistor. Some of this is going to also depend on what components you are using. The starter solenoid can require power or a ground to energize it.
