Old 03-09-2017, 11:03 PM   #21
updraught
updraught's Avatar
Default Re: Model A Radiator Filter from Caterpillar
I got a Gano a year ago to protect a new radiator with a cleaned block and postage to here was $7. Postage now seems to be $32.
Anything more than the odd rust flake and I'd be cleaning the block.
updraught is offline   Reply With Quote
Old 03-10-2017, 08:15 AM   #22
Tom F OHIO
Tom F OHIO's Avatar
Do the gano filters go inside the hose??
Tom F OHIO is offline   Reply With Quote
Old 03-10-2017, 08:35 AM   #23
Brian SATX
Brian SATX's Avatar
You have to cut about 2 inches out of the center of the hose. Then the filter is set in the cut area and clamped in. You can see the filter in the cut area so you know when it needs to be cleaned. If you look at the yellow tab on the photo, you see how it fits in.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 03-11-2017, 07:47 AM   #24
Tom F OHIO
Tom F OHIO's Avatar
Thanks Brian. That clears that up for me.
Old 06-02-2017, 09:18 PM   #25
Tom Wesenberg
Tom Wesenberg's Avatar
Bringing this back to the top, as someone asked to see the filter and number.
Old 06-02-2017, 09:30 PM   #26
RawhideKid
I have one of those, and to see the water moving I clamped a short piece of ribbon between the two pieces and let the end drift into the filter. Check and clean regularly.
I started cleaning mine every other day of driving and went to every week of driving after it started to clear up the crud.
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 06-03-2017, 06:09 AM   #27
ronn
thank you Tom!
xlnt!
