04-30-2018, 07:45 PM | #1 |
Coil
The best coil to use on a 1949 Ford with a 8BA Engine with the original distributor set up? Thanks very much!
Bob |
04-30-2018, 11:24 PM | #2 |
Re: Coil
Go to Napa and get a 6 volt coil for a 49 ford. or any new old stock.
One good thing they don,t need a resister. |
04-30-2018, 11:30 PM | #3 |
Re: Coil
I was at NAPA today per chance looking for the same thing, a coil for an 8BA.
They have one, Part #IC-7SB. It is 6-Volt and says right on the coil "No external resistor required". $19.99 |
05-01-2018, 08:52 AM | #4 |
Re: Coil
Thanks to all!
Bob |
05-01-2018, 08:55 AM | #5 |
Re: Coil
When it says on a coil "no external resister required "does that indicate the coil has 3ohms of RESISTENCE?. Thanks,
Bob |
05-01-2018, 08:58 AM | #6 |
Re: Coil
05-01-2018, 09:02 AM | #7 |
Re: Coil
05-01-2018, 03:56 PM | #8 |
Re: Coil
Take there word for it that its good. No testing needed.
05-01-2018, 04:23 PM | #9 |
Re: Coil
The volt meter wasn't to test the coil, he was currous about the ohms rating.
