08-20-2020, 03:44 PM | #21 |
Re: 1951 Ford Split Rims
The two pictured are Firestone RH-5° widow makers. Please find replacements. The best replacement is the 22.5” that is the tubeless replacement for the 20” tube type. I know of at least one available set, perhaps two. They will not be cheap. The narrowest tire available today is the 9R22.5” that is the equal of the tube type 8.25”-20”.
I think I also know of a set of the 19.5” tubeless wheels. These would be much less costly than the 22.5s. The safer locking side ring 20” wheels are the other option and can still be found in old yards, but living in MA you would have to watch for rust damage from decades sitting in rural yards. Private message me if you want contact info for the guys having the 19.5s and 22.5s. Stu
Stu McMillan Marmon-Herringtons |
08-21-2020, 02:49 AM | #22 |
It's my understanding that 19.5, 5 lug Budds can be found on some motor homes. The old GMC was suggested to me.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
08-21-2020, 05:21 AM | #23 | |
The 19.5 is the technical replacement size for the 17 tube type. They fit the rear brake drums of the big Fords just fine, but the 8R19.5 tires will be shorter in diameter than the 20 or 22.5. Few of these old big trucks are asked to drive the highways anymore so the reduced road speed isnt normally a deal breaker. Some tire dealers might try to suggest the metric sized 225/70R19.5 which also is specd for the 6.00 wide rim, but these are shorter yet at 32 vs 34 for the 8R19.5. Stu
