05-12-2020, 05:08 PM | #1 |
Carb Tester
I want to build a carb float level bench tester. Do any of y'all have one you could post pictures?
05-12-2020, 05:27 PM | #2 |
Re: Carb Tester
See page 12 of this excellent write-up by Tom Endy:
https://www.brattons.com/media/wysiw..._-_11-2007.pdf
05-12-2020, 06:01 PM | #3 |
Re: Carb Tester
Good article Jim, thanks for sharing
Think I'll try that float level tester on my Tilly
05-13-2020, 09:03 AM | #4 |
Re: Carb Tester
Try this,screws in the bottom of the float bowl on the car .https://www.mikes-afordable.com/product/A9599.html..
It's not the destination ,it's the journey . |
05-13-2020, 09:15 AM | #5 | |
Re: Carb Tester
05-13-2020, 10:44 AM | #6 |
Re: Carb Tester
05-14-2020, 11:05 AM | #7 |
Re: Carb Tester
There is an article in the May/June 2019 MAFCA Restorer on page 12-13 on how to build a test stand. Leaves some info out and is not too good, but a place to start.
05-14-2020, 09:06 PM | #8 | |
Re: Carb Tester
Jim |
05-15-2020, 11:10 AM | #9 | |
Re: Carb Tester
With one shim - was the float solder line level, angled down, or angled up when upper carb/float is upside down, when compared to the upper half of the carb? Think I read somewhere it should be level. |
