08-30-2016, 07:00 PM | #1 |
Of Interest to members, a reminder of why to inspect your tow rig.
From Jeff Lee and the "Maritme Pre-War Car Registry", which I am a member.
"I don’t think too many of our PreWar members will be out trailering a Rolls with a Land Rover. But just the same, here are some unpleasant reminders of why you need to check out your tow vehicle, trailer and trailered car. And don’t forget to insure your car when you get it. Sometimes it pays to have the auto movers move old cars instead of ourselves." http://www.prewarcar.com/ https://www.youtube.com/watch?v=Qku6...ature=youtu.be Vehicle loading and tongue weight balance can be important especially with torsion bar load levelers. "Maritime Pre-War Car Registry" is a group of old car enthusiasts from mainly the Canadian Maritime Provinces (Nova Scotia. New Brunswick, Prince Edward Island) with a few members from North East States and Ontario, Canada, where I am from. As far as I am aware, the oldest running car in the Registry is a 1905 Cadillac and the newest that is usually on our tours is a 1940 Chevrolet Two Door. Jim |
08-30-2016, 07:59 PM | #2 |
Re: Of Interest to members, a reminder of why to inspect your tow rig.
im glad noone was hurt, but from thier website they speclate the air suspension of the land rover suddenly failed. when yo have airbags as spring and all of a sudden you have no springs yea doesnt take much to go outa control.
Im guessing that trailer doesnt have any brakes?
1929 Model AA - Need long splash aprons! |
08-30-2016, 08:28 PM | #3 |
What a shame.
a) the driver of the Range Rover clearly did not know what he was doing. b) The Range Rover is decidedly a very poor choice of a towing vehicle in this case. It is not heavy enough. We have worked on several Range Rovers here in this shop and frankly we feel they are engineered and built very poorly. I myself would not tow a kid's wagon with one c) I seriously doubt the trailer had its own brakes else I doubt this would have happened. d) I doubt tongue weight was anywhere near correct...I bet the rig was fishtailing e) I think the most likely explanation is jack knife, from which there is no recovery just my opinion of course
'31 180A Last edited by tbirdtbird; 08-31-2016 at 11:36 AM. |
08-30-2016, 09:45 PM | #4 | |
Once a jackknife occurs, there is no recovery but if you know what you are doing, even a big sway can be recovered. Wonder what his dry cleaning bill was????
08-31-2016, 01:27 AM | #5 | |
In Europe the trailer will have had brakes. I suggest you stop speculating about an article's speculation and learn the facts. |
08-31-2016, 05:17 AM | #6 |
Looks like it fish tailed a few times ... getting bigger and bigger each time ... whipping the Range Rover from one side of the road to another until the Range Rover flipped. If you have ever seen this happening when it is coming towards you, you won't forget it. |
08-31-2016, 07:19 AM | #7 |
Looks to me like the Rolls should have been towing the Range Rover.
08-31-2016, 10:38 AM | #8 |
It leaves us with a lot to think about! I haven't done that much towing in my life but thank God none it wound up like this poor guy. The closest I ever came was with my first trailer. It was empty and it fishtailed quite a bit. I was taking it to get it welded and the hitch broke off and it wound up freewheeling into a farmer's field. I never even knew till I checked the mirror and saw it was gone. I found it about a mile back. I used every piece of chain and rope on board and didn't have far to go.
Terry |
08-31-2016, 11:34 AM | #9 |
haha looks like someone struck a nerve. Ya have to wonder why everyone on this side of the pond is hauling with 1/2 or 3/4 ton pickups or larger...
the video speaks for itself
'31 180A Last edited by tbirdtbird; 08-31-2016 at 12:10 PM. |
08-31-2016, 11:35 AM | #10 |
Silverado 2500 the best tow vehicle you can buy.
I feel bad for the guy. My speculation was he was traveling to fast with too heavy a tongue load causing fishtailing as others have said. It appears to be on a long straight away. So we know he didn't hit a curve too fast. Instead of just dropping his foot off the gas he probably tried to steer out of it. Range Rovers are great dual purpose vehicles I'm sure but a short wheel base makes for tricky towing especially with an extra heavy load that's too far forward on the trailer. Always step back and asses your load before you strap it down. Its ok to move the car around to make it safer.
Blackwall Panthers Nor Cal chapter |
08-31-2016, 01:21 PM | #11 | |
08-31-2016, 02:03 PM | #12 |
yeah I got that backwards
08-31-2016, 02:22 PM | #13 |
Yep, been there done that. I went to pick up a 1929 Chevy 1 1/2 ton truck, and the seller loaded the truck bed full of tires and other parts. Luckily I only had about 80 miles to drive and it was way out in the country, because I had to drive no faster than about 22 MPH all the way home.
08-31-2016, 03:18 PM | #14 |
too much hitch weight will take weight off the front wheels of the tow vehicle and you will have understeer
GMC has info on how to calculate what your tongue weight should be http://www.gmc.com/gmc-life/trucks/w...fe-towing.html You can use a bathroom scale and a length of 4x4 to calculate your tongue weight yourself. Google it
'31 180A Last edited by tbirdtbird; 08-31-2016 at 03:50 PM. |
08-31-2016, 05:59 PM | #15 | |
I think you mean not enough hitch weight. I've never seen (or heard of) a trailer whipping from TOO MUCH hitch weight but too little hitch weight and it's impossible to control. As the link says, tongue weight (known here as drawbar weight) should be about 10-15% of the all up weight of the trailer. Let's say the trailer and Rolls weighted 4 tons. That would mean a tongue weight of 800-1200 pounds. I'm not so sure that tow car would handle that much weight on its @ss very well. I've seen one of these with the tow bar pulled out of it when towing a mid sized caravan. WRONG CHOICE OF TOW CAR. As for impossible to control - you've only got to know when to hit the brakes to straighten it out. I've done it. Recovered from a sway so wide that I could see the side of the trailer in the rear view mirror. I was on a busy 3 lanes each way road and it was amazing how quickly I had it all to myself.
08-31-2016, 07:31 PM | #16 |
Synchro you are a lucky boy. I hope you bought a lottery ticket that day. True the only way out of fishtailing is braking and ice in your veins. Harmonics will not be denied. But if you don't catch it.....take your choice of flipping or jack knifing.
That car would barely properly haul a lightweight Model A roadster on a 14' trailer
'31 180A |
08-31-2016, 09:05 PM | #17 | |
09-01-2016, 11:40 AM | #18 | |
Look at the facts. http://www.uktow.com/towing%20capaci...=Range%20Rover |
09-01-2016, 12:05 PM | #19 |
Just about every day I see something like this ....
This was the westbound I-90 about (2) weeks ago just west of Billings, MT. Ironically I am headed to Billings today to drop off a 1938 Cadillac .... Jim |
09-01-2016, 03:26 PM | #20 | |
