Old 08-02-2019, 07:39 AM   #1
ckulchar
Default Sparking at starter switch
Yesterday we drove the 1931 pickup. Started four or five times without any issues. Last night when I attempted to start the vehicle to put in the garage. While holding the starting foot pedal down I only got some arcs below where the foot pedal rod connects to the starter switch.
Removed the starter this morning. Took off the starter switch and band. Bendix was free on shaft, brushes were worn about half, and starter rotated by hand easily. Cleaned the copper button on top of starter. Put the starter back together less the starter switch. Got jumper cables and clamped positive cable to bolt hole lug and touched negative cable to copper button on starter. Started spun as expected. Put the starter switch back on starter and attached to engine. Pressed the start pedal and got the same arcing as before. No attempt for the starter to rotate.
What are the symptoms of a faulty starter switch? Any other ideas?
Thanks in advance.
Charley
ckulchar is offline   Reply With Quote
Old 08-02-2019, 10:29 AM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: Sparking at starter switch
Sound like the starter switch is not isolated and the switch is short to ground?
Farrell In Vancouver is offline   Reply With Quote
Old 08-02-2019, 10:35 AM   #3
Purdy Swoft
Purdy Swoft's Avatar
replace the cardboard insulation inside the starter switch .
Old 08-02-2019, 10:40 AM   #4
Jim Brierley
Both Ferrell and Purdy are right. I also put a piece of rubber gas line over the starter push-rod, it insulates, quiets and blocks out hot air.
Old 08-04-2019, 09:22 AM   #5
Elcastor
Elcastor's Avatar
If it is a reproduction switch, that is the problem. The case of a replacement switch is more rounded at the top, and can short out.
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 08-04-2019, 05:54 PM   #6
marty in Ohio
marty in Ohio's Avatar
Charley,
These all sound like good advice. Big John and I talked about your problem the other night. Let me know if I can help.
Marty
marty in Ohio is offline   Reply With Quote
Old 08-04-2019, 10:35 PM   #7
1955cj5
1955cj5's Avatar
Here is a picture of a repro switch I robbed the internal parts from to rebuild my original.
You can see the cardboard insulator and also the plastic insulator that fits into the plunger and insulates it from the copper contact. I don't know what material the original used for the plastic insulator, mine was missing.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-05-2019, 06:35 AM   #8
ckulchar
Purchased a new starter switch and that fixed the problem.
Appreciate everyone's help.
Charley
