Old 11-16-2020, 10:04 PM   #1
Dobie Gillis
Dobie Gillis's Avatar
Default Pressurizing Rocker Shafts
I'm considering pressurizing the rocker shafts on my '55 292. I know there are at least a couple of methods, pinching off the shaft drain tubes appearing to be the easiest. My concern is about possibly starving some other part of the engine for oil. It looks like the output of the passenger side shaft goes to the timing chain. I don't know where the oil from the driver side tube goes, distributor/oil pump drive gear maybe...? I'm pretty sure a few guys here have done this so I'd like to know what method you used and the results before I pull the trigger. TIA for any advice.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
