Old 06-10-2019, 02:48 PM   #1
1930artdeco
1930artdeco's Avatar
Default HF infrared gun reviews
Hi All,
Anyone have any reviews good or bad about the Harbor Freight Infrared gun? I may get one to verify the rad temps.
Thanks,
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-10-2019, 02:55 PM   #2
Roxo
Roxo's Avatar
Default Re: HF infrared gun reviews
I bought one and it seems to be pretty accurate.
Roxo is offline   Reply With Quote
Old 06-10-2019, 03:12 PM   #3
SteveM
I got one and I've used it for all sorts of stuff from checking brake rotors to melting chocolate (yes, you really need to immerse a thermometer to properly measure the chocolate, but it gets me a quick reading - when I need to immerse a thermometer, I use my tire pyrometer).
I bought it checked my rotor temps and it confirmed I had a sticking caliper - paid for itself the day I got it.
Steve
SteveM is offline   Reply With Quote
Old 06-10-2019, 04:55 PM   #4
Ray in La Mesa
Mine's worked great for years.
Ray in La Mesa is offline   Reply With Quote
Old 06-10-2019, 05:56 PM   #5
Gastrap
Gastrap's Avatar
I have the HF one at home, and one from the Snap-On truck at work. They work equally well. The HF one actually has a finer laser dot.
Gastrap is offline   Reply With Quote
Old 06-10-2019, 06:49 PM   #6
30 Closed Cab PU
Am not sure about the HF model, but a lot of them go haywire due to ignition noise. If I have it in the cab of my PU on the floor, it actually turns itself on and beeps erratically with the motor running, if put behind the seat it is OK.
I have found I have to stand at least 4 ft. away from what I am measuring if the motor is running. Also on mine (not HF) really can not see the laser in direct sunlight.
30 Closed Cab PU is offline   Reply With Quote
Old 06-10-2019, 10:01 PM   #7
holdover
My HF unit is about 5 yrs old, no problems and accurate as well. As a plus my cats like running after the laser (just don't shine it in their eyes!
holdover is offline   Reply With Quote
Old 06-10-2019, 10:05 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
I like it.
Old 06-11-2019, 12:13 AM   #9
Bill G
Bill G's Avatar
My HF temp gun has no issues being used close to the running engine and it seems to be pretty accurate
Bill G is offline   Reply With Quote
Old 06-11-2019, 07:04 AM   #10
chap52
chap52's Avatar
Mine has worked fine for many years. Chap
chap52 is offline   Reply With Quote
Old 06-11-2019, 07:31 AM   #11
77Birdman
I have a Ryobi, got it from HD for less than $30. Works great!
77Birdman is offline   Reply With Quote
Old 06-11-2019, 07:35 AM   #12
30 Closed Cab PU
I was not planning on using mine more than a limited few times, and bought a very cheap one. Guess I got what I paid for since others here have not had the same issues.
Old 06-11-2019, 07:36 AM   #13
Terry, NJ
Terry, NJ's Avatar
Not trusting HF, I went to Lowes for mine. I rebuilt my rear and wanted to measure the heat rise. At 80 ambient, it was only 110 after climbing a long hill. These can be used to figure out the timing also. I was not advancing the timing enough and getting over 200 after climbing the same hill. It was over200 at the top of the radiator and about 170 at the bottom. I don't know what the heat rise should be, but it normally runs about 180.
Terry
Terry, NJ is offline   Reply With Quote
Old 06-11-2019, 09:13 AM   #14
1930artdeco
Thanks folks. I just put a new head gasket on and I don't want to do it again due to overheating. Especially since I cleaned things up.
Mike
1957 Country Sedan
Old 06-11-2019, 10:54 AM   #15
denniskliesen
denniskliesen's Avatar
I have a few of them and they work fine. I try to wait and save using coupons or buy when on sale. Recently bought one of their Ames brand on sale for $9.99 and it works fine. You have to buy a 9 volt battery for the Ames, does not come with it.
denniskliesen is offline   Reply With Quote
Old 06-11-2019, 02:52 PM   #16
1931 flamingo
1931 flamingo's Avatar
For the price it will get you in the ball-park.
Paul in CT
Old 06-11-2019, 08:46 PM   #17
Corley
Keep in mind that those measure the temp of radiated heat waves. Different colors radiate differently, as do irregular surfaces. Black is the best color to measure.
Just a warning, you might want to consider.
Corley
Subscribed to the KISS principle!
Corley is offline   Reply With Quote
Old 06-11-2019, 09:23 PM   #18
28
the ones on amazon for $14 work well too.
28 is offline   Reply With Quote
Old 06-12-2019, 10:12 AM   #19
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Will they tell if your Chicken is DONE???
Bill Hungry
"THE ASSISTANT GURU OF STUFF"
Old 06-12-2019, 10:28 AM   #20
katy
katy's Avatar
Bill Hungry
NO, you need a probe type thermometer for that, as you need to read the temperature INSIDE the meat.
Thread Tools
Display Modes
