Old 07-20-2012, 08:08 AM   #1
cuddles1
Default Halogen Lights-47 Ford
Any you boys try those Halagon head lights from "Drake"; if so how did they fit??? Thanks much !!!
cuddles1 is offline   Reply With Quote
Old 07-20-2012, 09:25 AM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: Halogen Lights-47 Ford
Tried a pair several years ago. No matter how may times I tried to align them, there always seemed to be a big dead spot in front of the car. Finally went back to conventional sealed beams.
4dFord/SC is offline   Reply With Quote
Old 07-20-2012, 09:46 AM   #3
Old Henry
Old Henry's Avatar
You can put halogen sealed beams on the '47 like I did on mine. Noticeabley brighter than the regular sealed beams. Available off the shelf at NAPA: http://www.napaonline.com/Catalog/Ca...006_0325911338
Old 07-20-2012, 10:44 AM   #4
41ford1
41ford1's Avatar
If those are the Wagner Lighting H6006 unit they are no longer made. they stopped production in 2009. You can find them on the bay or if your lucky at a long time local parts store. My local store had 24 on the shelf in March at $8.99 ea. Then 0 a month later.
41ford1 is offline   Reply With Quote
Old 07-20-2012, 10:50 AM   #5
Old Henry
Old Henry's Avatar
I just called my local NAPA store and they have two on their shelf.
Old 07-20-2012, 11:50 AM   #6
Steves46
Steves46's Avatar
Henry, if you are running w/stock 6-volt system, the generator is able to keep up? I heard these lights tax generator output. Steve
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 07-20-2012, 12:07 PM   #7
Old Henry
Old Henry's Avatar
Everything taxes the generator output - the headlights, the brake lights, the spot light, the radio, the heater fan. Just gotta keep the generator turning a bit faster than normal idle and it can keep up unless everything is on, then it doesn't. The biggest drain I've noticed is the old tube radio. It seems to take more than any other two combined. I didn't notice a big difference between the stock lamps and the halogen. I certainly didn't have to put in any heavier wiring or a relay or anything like that. Just plugged them in and away we went - seeing better than before.
Old 07-20-2012, 10:17 PM   #8
41ford1
41ford1's Avatar
This one has a pair of the Wagner H6006s They are much brighter than the standard sealbeams. The Courier is 6v pos ground with a generator. There is no problem when running these at night. The ammeter shows about 10 amps charge when these are on at 35 to 50 MPH.
Old 07-22-2012, 08:48 AM   #9
cuddles1
Thank's to all for your aid and assistance with the Halogen question.......Dave
Old 07-22-2012, 12:28 PM   #10
Steves46
Steves46's Avatar
My local NAPA has the H6006 available so I may try a set on my 46. Thanks for the info.
