Old 08-05-2016, 08:16 PM   #1
47Sooner
47Sooner's Avatar
Default A little progress
Haven't posted much since I joined but finally making a little progress on my 47. In the process of rebuilding the front end and replacing my tired flathead. I know Henry made some quality spring hanger bushings because I had a time removing them. Still had FORD and USA on the bushings. Sticking with the original three speed trans for now. Probably will be driven mostly local anyway. Maybe a quick drive to Tulsa but I can go Route 66. I've read posts on recommended oil but was thinking maybe some Valvoline VR-1 30 for break-in.
47Sooner is offline   Reply With Quote
Old 08-06-2016, 05:53 AM   #2
tubman
tubman's Avatar
Default Re: A little progress
Nice lookin' all around. As to special break-in oil, I don't use it. I like to change the oil and filter at around 50 and 500 miles. I'm kinda' cheap and would hate to see all if that expensive oil in the drain pan after a couple of hours use.
Old 08-06-2016, 06:24 AM   #3
TagMan
Why spend thousands of dollars on a new engine and not break it in correctly? The first few miles on a new engine are critical. Use the break-in oil.
TagMan is offline   Reply With Quote
Old 08-06-2016, 08:19 AM   #4
47Sooner
47Sooner's Avatar
I was trying to stay with an oil with a higher zinc content on break-in, if possible. I see some say they use 10-30W oil.
Old 08-07-2016, 12:27 AM   #5
prez
those bushings are a lot of fun alright !
please tell me what front axle is that ?
dropped with shock mounts , just what I need
for my 46
prez is offline   Reply With Quote
Old 08-07-2016, 06:41 AM   #6
47Sooner
47Sooner's Avatar
for my 46
It's a Magnum 4 inch dropped axle with a 3 inch Posie spring.
The axle was a great fit with no problems.
Old 08-07-2016, 10:16 AM   #7
19Fordy
19Fordy's Avatar
47Sooner:
Did you also have to use magnum dropped steering arms with your axle?
Old 08-07-2016, 12:58 PM   #8
47Sooner
47Sooner's Avatar
Originally Posted by 19Fordy View Post
47Sooner:
I haven't yet. We have planned on trying to heat my arms but if this doesn't work correctly, I'll will buy the Magnum arms.
Old 08-10-2016, 06:44 AM   #9
47Sooner
47Sooner's Avatar
47Sooner:
You are correct, sir ! I ordered the dropped steering arms.
Old 08-10-2016, 07:07 AM   #10
JSeery
JSeery's Avatar
IMHO the best axles are the originals that are dropped!
