Old 05-30-2016, 08:00 PM   #1
gearhead1952
gearhead1952's Avatar
Default 51-52 Truck Magic Air Heater Tubes
City: Arvada
State: Colorado
Price: In ad
I have some Magic Air fresh air heater tubes and parts for sale.
The front and middle sections are the same for both years. Only the cowl side piece is different. The heater port is round on the 51s and square on the 52. The top two setups are 51 and the bottom two cowl side pieces are 52. Good solid metal except where noted. I have numbered them for reference.
1) Very nice rust free, no damage, will need studs repaired. 4 pcs. ** SOLD **
2) Good shape has one small hole on bottom side of cowl piece, will need studs repaired, ring for boot needs work. 4pcs $85
3) Good shape, needs the flange repaired for cowl piece and studs repaired. 3pcs $80
4) Front piece only. Needs screen and stud repair. 1pc $15
5) Front piece only. Needs stud repair. Edge of tube is ragged from rust. 1pc $15
6) Cowl side piece only. Good sized hole in tube. 1pc $15
gearhead1952 is offline   Reply With Quote
