Old 04-16-2013, 07:07 AM   #1
Brendan
Brendan's Avatar
Default V8 water pump
The water pump on my 29 Roadster with an A motor just went out. I bought the car about a month a go. so is there a place that I can get a new water pump with the pulley set up on it. their is also a Clings serpentine belt and fan on it also. can you help ne out? thanks, Brendan
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 04-16-2013, 07:58 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: V8 water pump
Brendan, when you said "it went out", ....exactly what does that mean? Did it start leaking? Did it break in half??
I also am not sure if you have a V-8 pump with an adapter or a regular-style Model-A pump. Generally speaking, if a serpentine belt is used on a regular Model-A pump, the natural tendency is to tighten the belt too tight which ruins the front bearing on the pump. With that said, I also do not see a value in a serpentine set-up. I do see the value in a race car application where parasitic Hp draw is a factor but when the original belt is properly installed, the Hp consumed is negligible and the water pump wear is all but eliminated. Might I suggest if possible that you revert the system back to an original style pump, fan, and belt system.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-16-2013, 08:13 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Sacramento Vintage Ford Pt number 5733
Old 04-16-2013, 08:39 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with Brent, and an original pump is easy to rebuild. I rebuilt mine about 15 years ago and have been running it for the past ten years without leaking a single drop.
Last fall, after the vinegar rust removal treatment, I installed a rear bushing with the seal in the back of it. This will keep the grease and antifreeze from mixing with each other.
My old used temporary engine had an accumulation of rust in the rear of the block. After years of running many of the rust flakes came loose and plugged the radiator until coolant came out the overflow. I also installed a drier sock to trap any future rust that may be remaining, but I feel confident that 30 days of running pure white vinegar got rid of the rust.
Old 04-17-2013, 09:54 AM   #5
richard orlandi
richard orlandi's Avatar
Brendan, How about using the whole V8 Motor instead
of only one V8 water pump ? Then you would have an A-V8 .
Rich ..............
36Panel Delivery
richard orlandi is offline   Reply With Quote
Old 04-17-2013, 10:45 AM   #6
BRENT in 10-uh-C
Rich ..............
....and the benefit would be???
BRENT in 10-uh-C
Old 04-17-2013, 11:46 AM   #7
Kirby1374
Kirby1374's Avatar
better water pump.........lol
Kirby1374 is offline   Reply With Quote
Old 04-17-2013, 06:44 PM   #8
Brendan
Brendan's Avatar
Rich ..............
I got a good 37 motor in my shop!
Old 04-17-2013, 06:47 PM   #9
Brendan
Brendan's Avatar
so what do you guys think about the V8 pump , have other guys had trouble with them?
can you let me know? their is about 1/4 inch of play in the pump the bushing failed
Old 04-17-2013, 07:40 PM   #10
Brendan
Brendan's Avatar
hope this helps
Old 04-29-2013, 06:47 PM   #11
Brendan
Brendan's Avatar
i wont to put on a Model A water pump on my car, so where can i get a Cling serpentine pulley for a Model A pump? i don't wont to change all my pulleys . can you guys help me Thanks Brendan
Old 04-29-2013, 07:33 PM   #12
Brendan
Brendan's Avatar
so what do you think!
Old 04-29-2013, 07:57 PM   #13
Tom Wesenberg
Are you saying that right now all the other pulleys are serpentine?
Old 04-29-2013, 08:04 PM   #14
gwhite
gwhite's Avatar
Call Cling's and see if they'll sell you one. They make a kit "KIT B" for stock Model A with alternator - https://www.clingsaftermarket.com/addtocart.asp?prod=32
And I'm still interested in that Cyclone pump adapter
gwhite is offline   Reply With Quote
Old 04-29-2013, 10:03 PM   #15
Brendan
Brendan's Avatar
yes, all the pulleys are serpentine. I would like to just change the water pump and the water pump pulley
Old 04-29-2013, 10:05 PM   #16
Brendan
Brendan's Avatar
I have called and left massages and tried to Email them and the address is no good!
Old 04-29-2013, 10:14 PM   #17
Mike V. Florida
What other belts do you have on the engine that you want to match them?
Old 04-29-2013, 10:22 PM   #18
Brendan
Brendan's Avatar
the crank pulley and the pulley on the alternator, are serpentine also the one for the V8 water pump. I would like to get a serpentine pulley for a Model A water pump. I bought a V8 pump from Dennis Carpenter but the shaft is to big and the housing is very different from the old pump, after reading and thinking about this I think that a model A pump is the way to go. but I just wont to change the pulley on the water pump
Old 04-29-2013, 10:26 PM   #19
quickchange
quickchange's Avatar
I have spare v8 pumps, spare adapters, one has adapter with v8 pump & plastic fan.
Looking at your set up has correct belt to run orig A pump,
quickchange is offline   Reply With Quote
Old 05-02-2013, 06:10 PM   #20
Bob C
The email in the newest Restorer is [email protected]
