Old 01-11-2013, 07:51 AM   #1
Zimmco
Zimmco's Avatar
Default 35 Pickup Bed question
I need some guidance on my pickup restoration. Does anyone know whether the wood under the steel floor was painted when the bed was painted? I've seen pickups with a steel floor and bare wood under it, but it doesn't seem to me that Ford would have asssembled them this way and masked off the wood. I'm sure this will be the first of many questions as I proceed!
Thanks,
Al
Zimmco is offline   Reply With Quote
Old 01-11-2013, 08:07 AM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: 35 Pickup Bed question
Al,
On the '40, all the wood was painted a flat black, including the mounting wood for the cab as well.
Cecil/WV is offline   Reply With Quote
Old 01-11-2013, 08:12 AM   #3
flat-v8
flat-v8's Avatar
They were not painted originally, maybe treated with oil or something, I replaced bad wood then painted mine with urethane, many many coats, the wood sucks up alot of paint!
flat-v8 is offline   Reply With Quote
Old 01-11-2013, 01:23 PM   #4
Lawson Cox
Lawson Cox's Avatar
Based on our research to date it appears that the wood under the metal floor in the bed, and the wooden cab and bed supports were not painted. I have seen several original beds that had overspray around the edges of the wood, but none in the center.
Old 01-11-2013, 04:10 PM   #5
TJ
TJ's Avatar
MinWax makes a product called Polyshades. It's a stain that has polyurethane in it. You can get it in black and really works well. Would be a good preservative for the wood under the steel bed.
Old 01-12-2013, 11:41 AM   #6
jerry grayson
Lawson, I have some information on this subject that you may not be aware of. I replaced the floor (metal and wood) on a 36 bed and kept the old wood. I looked at it today and cleaned off the top of the pieces and it looks like the wood was coated very lightly with some weak black paint. The bottom of the wood pieces is covered with gray primer like the remainder of the bed, so I can't tell what the orignal was, but the top of the wood for sure has some black coating. From this evidence, I assume that the wood was coated from the factory with weak black paint, top and bottom, before being installed in the bed assembly. I do not think that the bottom of the bed was painted with the final color during the color painting.
jerry grayson is offline   Reply With Quote
Old 01-14-2013, 09:33 AM   #7
Zimmco
Zimmco's Avatar
Thanks to all for your input. It'll be a while before I get to paint, but this is great info.
Old 01-14-2013, 11:28 AM   #8
HOTRODPRIMER
HOTRODPRIMER's Avatar
The Minwax polyshade finishes are designed for interior use only.
They make a spar urethane clear for exterior,,but the wood was painted black that was under my bed. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
