Old 03-27-2024, 11:52 AM   #1
jeepguy1948
Default Brake Drum Paint
This question is definitely not limited to early V8’s but this seems a good place to ask. I am installing the Lincoln brakes and want to paint the drums before installing them, I absolutely cannot stand rust and unfortunately where I live it rains. What paint works best? I know that it has to be a high temp paint but which one? Barbecue paint? Brake Caliper paint? I doubt that engine paint can stand the heat.
jeepguy1948 is offline   Reply With Quote
Old 03-27-2024, 04:46 PM   #2
cas3
Default Re: Brake Drum Paint
I would use black epoxy primer and thats it. I don't think you will ever get brakes hot in normal use unless pulling a trailer down hill. I use regular 2 part urethane paint on engines, never had a need for "high temp" paint.
Old 03-27-2024, 07:25 PM   #3
19Fordy
19Fordy's Avatar
I painted my Lincoln brakes with Rustoleum black paint-brushed on. I think high temp engine paint from a spray can would be better.
I have been told that unpainted brake drums dissipate heat better than painted.
If that's true flat black bar-b-que spray paint would be best.
More info here:
https://www.jalopyjournal.com/forum/...drums.1256746/
Old 03-27-2024, 07:55 PM   #4
Kube
Kube's Avatar
I have always had mine powder coated. They mask the bearing and braking surfaces. Reasonable, beautiful and long lasting.
Old 03-27-2024, 09:23 PM   #5
petehoovie
petehoovie's Avatar
More info here:
Old 03-27-2024, 09:25 PM   #6
fordor41
fordor41's Avatar
I painted our drums on our '41 in '95 with Rustoleum black. They were like new when we sold it 25 yrs later.
fordor41 is offline   Reply With Quote
Old 03-27-2024, 10:04 PM   #7
jeepguy1948
Powder coating is something I hadn’t thought of….
Old 03-28-2024, 07:41 AM   #8
sidevalve8ba
sidevalve8ba's Avatar
I have done it two different ways. On one car I had them powder coated and they have held up quite well. No problem. On another car, on which I was being frugal, I just used black BBQ grille paint and it has held up surprisingly well. And the beauty is touch ups are easy.
The more I learn about new automobiles, the more I value my old ones.
sidevalve8ba is online now   Reply With Quote
Old 03-28-2024, 09:32 AM   #9
Planojc
Planojc's Avatar
How about POR 15
Planojc is offline   Reply With Quote
Old 03-28-2024, 11:04 AM   #10
TJ
TJ's Avatar
POR 15 will work. I have used it on drums.
Old 03-28-2024, 11:32 AM   #11
Bored&Stroked
Bored&Stroked's Avatar
That is exactly what I do! I also use a high-temp filler to fill-in the dang areas on the drum with the recessed lettering (new repop drums) - can't stand looking at those letters . . . but hey, I'm a bit anal about certain things! LOL
