Old 03-21-2017, 07:56 AM   #21
pgerhardt
pgerhardt's Avatar
Default Re: Looking for a Good Soul to Detail the Marvel Carburetor
Originally Posted by gz View Post
I don't know anything about them but I have had one on my roadster for years and it works great. Better, in my opinion than a Zenith or Tillitson. I acquired mine by accident-at a swap meet early one morning and bought it thinking it was a Tillitson until I got it home and looked at it. What the heck, I figured, I'll give it a try. I took it apart, cleaned everything, and put it back together and I really like it a lot. I'd by another one if I ran across one. It does worry me that there are no parts available that I know of. I made a really crude gasket for it that seems to work.
Rennerscorner.com has parts for the Marvel. (search for Alstate, not Marvel)
pgerhardt is offline   Reply With Quote
Old 03-21-2017, 08:14 AM   #22
41plym
I have bought two rebuilt marvel carbs off ebay from a guy in Texas. He has them all the time, just bolt on and go they work awesome. He also sells rebuilt tillitsons.
41plym is offline   Reply With Quote
Old 03-21-2017, 09:03 AM   #23
jhowes
Question that I have is; "is the gav valve interchangeable with the Tilly or the Zenith?" Jack
jhowes is offline   Reply With Quote
Old 03-21-2017, 09:05 AM   #24
GMCPASO
GMCPASO's Avatar
No, there is only the patent numbers on it.
GMCPASO is offline   Reply With Quote
Old 03-21-2017, 09:27 AM   #25
TinCup
TinCup's Avatar
I really like these carbs. I have rebuilt several from scavenged parts and they run out great. More information on these could only be better.
TinCup is offline   Reply With Quote
Old 03-21-2017, 10:12 AM   #26
Brian T
Brian T's Avatar
I have seen it stated that they do, 3 pieces, the tube, needle, and choke driver, I believe it was Ron Rude that knows.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 03-21-2017, 11:35 AM   #27
1930artdeco
1930artdeco's Avatar
If I remember correctly not all of them will interchange. I would have to double check on my spares though...
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-21-2017, 05:41 PM   #28
GMCPASO
GMCPASO's Avatar
No number, just patent number. Oops, found number on mounting flange surface, HF 1 1145. Looks like a date stamp. Patent Number is 1,536,043. Also, in bottom of float bowl is # 10-A-126, probably mold number and on underside of top cover, # 227-104. ID of venturi is 0.8125 / 13/16".
Old 03-21-2017, 05:53 PM   #29
1955cj5
1955cj5's Avatar
Same on mine....thanks...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 03-22-2017, 03:10 PM   #30
GMCPASO
GMCPASO's Avatar
Hi 1955cj5,
On closer inspection, there is number stamped into the mounting flange, mounting surface.
It looks like it might be a date stamp, HF 1 1145, if that is any help. Also, the patent number is 1,536,043.
GMCPASO
Old 03-22-2017, 03:36 PM   #31
1955cj5
1955cj5's Avatar
Thanks I'll look next time its off....the patent # on mine is on the side against the block...can see it but can't read it through a mirror!
Old 12-29-2019, 12:02 AM   #32
saxman657
You are referring to JR (Jim) Bullock of Texarkana, TX. He now has a website: www.jmacarbs.com Email: [email protected]. Ph: 903-748-8299
saxman657 is offline   Reply With Quote
Old 12-29-2019, 12:38 AM   #33
Davew
Davew's Avatar
I have purchased Marvel Carberators from JR also and am very pleased with them. He also will take the time to visit about any model A issue. Nice guy.
Davew is offline   Reply With Quote
Old 12-29-2019, 11:33 AM   #34
JBill
I have one I don't use since the float once stuck and scared the bejeebers out of me. I recall they require a slightly different pipe fitting from gas line to carb than either the Zenith or the Tillotson. Yes? No?
JBill is offline   Reply With Quote
Old 12-29-2019, 12:19 PM   #35
saxman657
Yes, there is a brass adapter. I had a slight leak there after installing. I reinstalled last night with a small amount of Hylomar on the threads. Hope to not see leaks when I start her up today.
Old 12-29-2019, 03:37 PM   #36
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
https://www.vintagefordforum....com/...-i-must-marvel
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
