Old 01-23-2022, 06:30 PM   #1
rivcokid
rivcokid's Avatar
Default Water Pump - How to tell which one I have?
Hi all - in reviewing how to lubricate the Model A, everything says that you MAY have to lubricate the water pump, depending on which one you have. But nowhere that I can see does anyone tell you how to determine which one you have and whether you have to put grease in 1, 2, or 0 fittings. Is there a quick way to figure this out?
Thanks in advance.
rivcokid is offline   Reply With Quote
Old 01-23-2022, 07:31 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Water Pump - How to tell which one I have?
If the fitting will take grease give it a little. If not and is not a dummy, clean it out and give a squirt. If it is not meant to have grease it won't take any.
Old 01-23-2022, 07:42 PM   #3
rivcokid
rivcokid's Avatar
Thanks - I'll take a look tomorrow
Old 01-23-2022, 10:08 PM   #4
Gary WA
Gary WA's Avatar
Leakless Model A Water Pumps will this help
www.whidbeymodelaclub.com
Old 01-23-2022, 11:53 PM   #5
J Franklin
J Franklin's Avatar
Thanks in advance.
That is why I gave a down and dirty solution that did not care what waterpump he had without thorough examination. Gary, I do like the pumps in the article.
Old 01-24-2022, 08:15 AM   #6
rivcokid
rivcokid's Avatar
Thanks Gary - great info on pumps, but doesn't show the whole pump itself. I'm going to do as J Franklin suggests. Thanks!
