05-15-2011, 11:02 AM | #1 |
who rebuilds distributors?
any recommendations on who does a nice iob on rebuilding a 37 distributor? thanks tom
05-15-2011, 11:07 AM | #2 |
Re: who rebuilds distributors?
Bubba
05-15-2011, 11:34 AM | #3 |
GMC Bubba on the HAMB absolutely the best!
05-15-2011, 12:40 PM | #4 |
I can highly recommend Jim Linder (GMC Bubba) on the HAMB as well as these fellows from Texas (The Pit Stop):
http://www.thepitstopgary.com/ Oh, and Skip Haney in Punta Gorda, FL. All very good. |
05-15-2011, 02:15 PM | #5 |
Ken CT who often posts here rebuilds them. You could send him a pm for any questions/ details.
05-15-2011, 03:58 PM | #6 |
05-15-2011, 04:29 PM | #7 |
Skip Haney gets my vote, and while your at it, let him rebuild your coil for a complete set up.
05-15-2011, 04:44 PM | #8 |
05-15-2011, 04:46 PM | #9 |
05-15-2011, 05:52 PM | #10 |
Skip rebuilt my pumps and coil on the '34. Pit Stop upgraded the '34 to crab type distributor. Bubba solved the ignition woes on my '61. I'm an equal opportunity employer.
05-16-2011, 06:05 AM | #11 |
Location: Skaneateles,NY(summer)/Port St.Lucie,FL(winter
Jim Lindner (GMC BUBBA)...the BEST, fast, inexpensive...
..."If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit"... |
07-01-2011, 10:10 PM | #12 |
I guess I should ask him but what's the usual turnaround time with Bubba on a distributor?
Lee
Salt Is Good... Mk 9:50 |
07-02-2011, 08:28 AM | #13 |
I rebuild my own, its not that hard. My dad used to owned an original Ford distributor machine and rebuilt the distributors for all the V8 club members in the area. He started checking and the machine set all the styles of front mount distributors the same way. Dad wrote down the point settings and sold the machine. My memory is that the driver's side points are set 0.013 loose, 0.014 tight, and the passenger side points are set 0.015 loose, 0.016 tight. The advance on the side runs well on stock engines at about 4° advanced. Back the vacuum brake out all the way and adjust it in as necessary to keep your engine from having spark knock.
07-02-2011, 08:45 AM | #14 |
I'm with you 38 coupe, I have my green bible and the vern tardell #4 Ford ignition book. All the info I need, plus I got the barn for backup.
Now as far as vaccum is concerned, would you agree with 16-18" @ idle |
07-02-2011, 09:27 AM | #15 | |
I would really like to say we return the distributor the week we get them. However right now I am a couple weeks out with orders,hence working this sat. Moved out of a storage unit the last two weeks (20 years of stuff) that's done now should catch up in a couple weeks. So I would say one week turn around.." |
07-02-2011, 02:48 PM | #16 |
Hands down Jere Jobe from Vintage Carburetion North in Somers, MT.
He actually REBUILDS them, not just swap out the points and call it a day. |
07-02-2011, 11:22 PM | #17 |
Do your own, they're not hard. I just did mine, new bushes, new vacuum brake, as well as the usual points, cap, rotor, condensor and setup.
07-03-2011, 08:49 AM | #18 |
A flathead with stock camshaft, good valves, in good tune should hit 20" of vacuum or a little better (near sea level). That said, I don't think my 37 can do that, and it's not broke bad enough to require fixing (pulling the heads and lapping the valves).
