Old 09-11-2020, 06:36 PM   #1
harleycontracter
Default Spartan Ahooga horn question
To connect it wire goes to center terminal between the 2 posts I would assume. Is the other screw that is exposed outside the cover for sound adjustment?
Looked on line couldn't find anything
harleycontracter is offline   Reply With Quote
Old 09-11-2020, 07:01 PM   #2
Chris in WNC
Chris in WNC's Avatar
Default Re: Spartan Ahooga horn question
Two wires go into the horn, they plug into separate terminals.
the screw you reference is for the adjustment of diaphragm tension.
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 09-11-2020, 07:14 PM   #3
Mike Peters
Mike Peters's Avatar
Yes, and the two wires plug in 180 degrees apart facing each other.
Mike Peters is offline   Reply With Quote
Old 09-11-2020, 07:15 PM   #4
1955cj5
1955cj5's Avatar
The bullets on the wires slip into the clips in direction shown by the arrows.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 09-11-2020, 07:44 PM   #5
harleycontracter
Perfect Thank you everyone
