08-27-2020, 06:47 PM | #1 |
Positive Ground wiring situation
My friend bought a new 6 volt battery for his 51 Ford. I connected pos to pos and neg to neg. Everything seems to work alright but should I have done pos to neg and neg to pos???
Thank you, GW |
08-27-2020, 07:03 PM | #2 |
Re: Positive Ground wiring situation
Positive goes to ground and negative to the starter solenoid.
08-27-2020, 07:03 PM | #3 |
Positive post should go to chassis ground.
08-27-2020, 07:20 PM | #4 |
What happens if I do NOT put the positive post to the chassis ground?
08-27-2020, 07:38 PM | #5 |
Then you have reversed the current flow. This will work for some functions like lights, dash gauges, starter, etc. But it will not work correctly for the coil or the generator. It will reduce the coil output around 20%. Is there any reason to not connect it correctly?
If it has an external coil (can shaped coil) you can reverse the terminals so that it will function correctly, if you want it to run it reversed for some reason. Same with the generator, it can be setup to run with the reversed polarity. |
08-27-2020, 07:54 PM | #6 |
08-27-2020, 08:08 PM | #7 |
08-27-2020, 10:07 PM | #8 |
Thank you for answering....I'll just go change them and make it correct.
Just wondering what would happen because he does not live right by me. Now I can wait until I get back up there to his house. |
08-27-2020, 10:35 PM | #9 |
The way you first phrased that question makes it sound like you have it correct? You hooked his positive cable to the pos of battery, etc. Or what?
08-28-2020, 03:26 AM | #10 |
You may have problems with the radio.
Charlie Stephens |
08-28-2020, 08:14 AM | #11 |
Definitely not necessary to change the ammeter [emoji4].
I have just changed from negativ to positiv ground. You need the right voltage regulator. The new one can do both systems. Original Ford only work with positiv ground. I have killed 3 of them to get this information [emoji28]. Regards Thomas |
08-28-2020, 09:16 AM | #12 |
Sorry to tell you this if you hooked it up in reverse you have probably destroyed the voltage regulator.Be prepared to replace it.
08-28-2020, 09:49 AM | #13 | |
I don't think anybody said he needs to change the ammeter. |
08-28-2020, 10:46 AM | #14 |
08-29-2020, 03:00 PM | #15 |
