08-27-2020, 06:28 AM | #1 |
Brake backing plate
Brake ? Starting to re-assemble brake backing plate to spindle. Diagram shows castle nut on the rear of plate. When I removed it originally the castle nut was inside the grease baffle. I like that the threads were protected that way. Does it really make a difference?
08-27-2020, 07:36 AM | #2 | |
Re: Brake backing plate
08-27-2020, 07:53 AM | #3 |
Thanks Brent
08-27-2020, 08:32 AM | #4 |
YW. I probably should add that it is a whole lot easier installing them the proper way without dealing with a socket & cotter key inside the grease baffle.
08-27-2020, 11:39 AM | #5 |
Covid
08-27-2020, 12:30 PM | #6 |
08-27-2020, 05:36 PM | #7 |
I installed the proper way like Brent stated
