08-23-2020, 07:40 AM | #1 |
difference in F-1 frames ??
I am trying to put together a 51 F-1 pickup truck, I noticed thst there is A 46 f-1 frame which is available. Is this basically the same as the 51 without a lot of fit up ?? If not does someone have a 51-52 f-1 frame available in say the connecticut area or close to it ?? Tom
08-23-2020, 08:31 AM | #2 |
Re: difference in F-1 frames ??
Pre 48 was set up for lever action shocks. You will be drilling out rivits and adding bolt holes. |
