Old 08-21-2020, 08:13 PM   #1
Newc
Newc's Avatar
Default Aug/Sept project 2 to make 1 39 std cpe on sdn pan
Hi: youall will enjoy my misery, as I put this worn out cpe on a nice solid sdn pan. Both 39 Std's;The cpe was destined to be a race car until the sedan was found with a salvage title and a solid floor. I've never done this, but plenty of local V8ers have, sooo this a start post and I am 3weeks behind schedule as it is an outside job. Any advise is good and youall will get updates. I am using the sdn cowl and header- plan to cut just above the wiper towers as the sdn roof is higher, then cut at the rear fender mount points curve. Later Newc
Old 08-21-2020, 09:31 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Aug/Sept project 2 to make 1 39 std cpe on sdn pan
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 08-21-2020, 10:21 PM   #3
GB SISSON
GB SISSON's Avatar
Gol darnit Newc, while that isn't Arizona sheet metal. it is some fine looking beginnings from the Pacific NW. I see no reason why you can't come up with a really nice car with your efforts. I dream of some kind of easy driving V8 ford car and you know I have been 100% truck, but a warmed up V8 in a coupe could really get an old timer's blood flowing. I'm all in on this build!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 08-21-2020, 10:29 PM   #4
swoopNZ
MEMBER EMERITUS
I would not separate both cars at their pillars.
Cut out the sedan floor and install it in the coupe.
It will then retain much more of it's originality.
Sedan and coupe rear floor sections are way different.
Somebody may then buy the sedan and install another floor.
Another option is to buy new Drake/Carpenter or United Panel front and rear floor sections and install them in the coupe.
Not a big job.
swoopNZ is offline   Reply With Quote
Old 08-22-2020, 02:10 PM   #5
JSeery
JSeery's Avatar
Not sure I follow the reasoning on this. Why not just remove the subrails and floor pan from the sedan and move them over to the coupe? Messing with the door alignment in the cowl area seems like a bad plan.
Old 08-22-2020, 08:24 PM   #6
JHFORD51
I'd recommend removing the spot welds that hold the sedan rear floor to the front floor pan, drilling the spot welds at front cowl and behind c pillar, and then installing sedan front floor pans and rockers as an assembly in the coupe. Then I'd repeat with applicable portions of the rear section, although the coupe rear floor is different than the sedan.
Use lots of bracing and check door fitment often.
Although it looks scary, it's not a bad job once you start. Real simple the way these are put together.
If you need cows off the sedan for the coupe, I'd suggest making the splice in the trim line.
JHFORD51 is offline   Reply With Quote
Old 08-22-2020, 08:26 PM   #7
JHFORD51
Cowls...not cows!
Old 08-22-2020, 11:21 PM   #8
Newc
Newc's Avatar
Thanks for the interest; I have less than $2K in this experiment and am continuing as originally planned- cpe shell onto the 4dr pan. today's progress is about 2.5 hrs and was fun . A real learning experience. I even neglected to prebrace the components. what the heck- it is a 'beater' project so far. Photos here. And getting out of the cab while a load is up is a real no-no. Newc
Old 08-23-2020, 02:21 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
Man, I'm gonna go cook me a bucket of popcorn, 'cuz this just might get interesting! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-23-2020, 09:37 AM   #10
tub1
tub1's Avatar
I'm wondering why not cut the windscreen pillars easy join that way
tub1 is offline   Reply With Quote
Old 08-23-2020, 01:49 PM   #11
petehoovie
petehoovie's Avatar
Old 08-23-2020, 09:50 PM   #12
Newc
Newc's Avatar
tub1 is right except the rust damage in the cpe header is extreme. However I need to check the angle of the cpe header skin vs the sdn skin angle. On another similar swap there was a problem with the higher sdn roof. Taking a brief break. thanks Newc
Old 09-02-2020, 07:58 PM   #13
Newc
Newc's Avatar
Well a week+ later- made some progress to the final product. Tub1 was right about the A pillars, even more important [too late] I found the windshield angles are different- all the way to the cowl or windshield base! so I cut about 3 " too high for perfection. Anyway this coupe has been dubbed the 'Franken Coupe" for all its parts. Photos here, and I have NO help at all. the beer drinkers seem to know just when to show up later. Newc
Old 09-02-2020, 08:03 PM   #14
Newc
Newc's Avatar
I did this wrong; New photos here. Kind of looks like a '39 std cpe?? Newc
Old 09-03-2020, 08:54 AM   #15
tub1
tub1's Avatar
cool job well done
Old 09-03-2020, 09:27 AM   #16
TJ
TJ's Avatar
Hopefully the doors will fit without too much work. Interesting project.
Old 09-03-2020, 09:33 AM   #17
rockfla
rockfla's Avatar
What size are the A/T tires on the front of the sedan and are the any good, might could use them on a early jeep project?
Old 09-03-2020, 04:09 PM   #18
mercman from oz
mercman from oz's Avatar
Great progress. This swap is coming along very nicely. Keep up the good work.
Old 09-04-2020, 07:26 AM   #19
tub1
tub1's Avatar
now use the doors to set the gaps before you fire up the welding torch , exactly what I did with a 35 sedan and 35 ute some years ago it worked out sweet
Old 09-06-2020, 10:00 PM   #20
'36 5W
'36 5W's Avatar
Good advice from tub^^^. You may find the body a bit tweaked,
so door gaps will be a good place to start. Take many measure-
ments to be sure body AND frame are square, before and after bolting body down to frame.
Hell of a project to be tackling alone; you must have ice in your
veins and nerves of steel!
'36 5W is offline   Reply With Quote
