Old 08-02-2020, 10:10 AM   #1
bobsmanstuff
bobsmanstuff's Avatar
Default heater
Hey Guys, I didn't have a heater motor for my 53 customline and found one yesterday. The question I have is, there are to braided wires coming out of the fire wall. The motor has two red one's and a short one that I figure is a ground. If I were to hook up the other two and they were backwards would that hurt the motor or would it just turn backwards? Thanks Bob
bobsmanstuff is offline   Reply With Quote
Old 08-02-2020, 11:10 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: heater
Two wires could be indication of a 2 speed motor.
Depends on the switching that exists. Doubt it will run backwards.
Old 08-02-2020, 02:50 PM   #3
FortyNiner
FortyNiner's Avatar
Default Re: heater
Actually, depending on the heater type, the motor was designed to reverse direction for the defrost setting compared to the heat setting. Look at the blower fan (the barrel shaped one) after hooking up the wires and you'll know quickly if it's correct.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 08-02-2020, 05:37 PM   #4
bobsmanstuff
Default Re: heater
Thanks
Old 08-02-2020, 07:09 PM   #5
meric42
meric42's Avatar
Default Re: heater
The heater in my '53 also has 3 wires, one is ground and the others are for low and high speed. Don't ask me what the colours were as I had to recover min as the insulation was all but non-existent. I guessing that the short one will be ground and the other two will be for low and high, you should be able to connect power to these to confirm and polarity should not make a difference to rotation. I suggest using small clip leads so you can test before making a permanent connection.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 08-03-2020, 04:22 PM   #6
bobsmanstuff
Default Re: heater
Thank you -Bob
