Old 07-12-2020, 11:36 AM   #1
vernlee
Default 1953 f100
Hello everyone , my first post , I'm trying to get the backing plates off a 1953 f100 rear end to use on my model a , are the axles C clip , or do I just need a slide hammer to pull them out .
Vern
vernlee is offline   Reply With Quote
Old 07-12-2020, 11:49 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 1953 f100
Once the 4 bolts are removed, the axle assy with the outer bearing may just pull out. (no C clip) If not a little persuasion may be required.
Old 07-12-2020, 11:50 AM   #3
Fordestes
If the axle has a rear backing plate center cover (Dana/spicer) they are the clip style , if it has a pop out differential it is not the clip in type ,I have seen those axles replaced with later 9 inch pop out the front style housing .
Fordestes is offline   Reply With Quote
Old 07-12-2020, 01:52 PM   #4
vernlee
No C clips , rented a slide hammer , one side came out really hard , the other side about two whacks and it came out , thanks for the info I appreciate it
Vern
