Old 09-07-2020, 03:55 PM   #21
Werner
Werner's Avatar
Default Re: 1st gear is slightly jammed
2. gear jumps out (As written before, the 2nd gear jumps out.)
Today I tried an interesting experiment:
I noticed that the 2nd gear jumps out faster on poor paved roads than on a smooth track. When I watch, I see that the long gear stick vibrates more than a little bit.
My consideration is that the long gear lever ratio 5: 1 to the shift claw supports the wear on the forks and the pushing out the 2nd gear. Then I weighed the original heavy shift knob with brass threads. It weighs 2.05 ounces. Then I turned a wooden gear lever knob that weighs only 0.53 ounces.
The surprise was a success: the 2nd gear now rarely jumps out.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-07-2020, 07:25 PM   #22
GRutter
GRutter's Avatar
I would be concerned with the stress on the gear teeth when they are only partially engaged.. that is, while under load and sliding out of gear. Ignoring that problem could lead to failure.
GRutter is offline   Reply With Quote
Old 09-08-2020, 01:35 AM   #23
john charlton
john charlton's Avatar
I would bet your popping out out of second gear is due to wear on your cluster gear .I will look in my "stores" to see if I can help you . $ 500 does seem to be a high price for one delivered to your door taxes paid . I think they are around $300 in the USA catalogues .
John in humid cloudy morning Suffolk County England .
john charlton is offline   Reply With Quote
Old 09-19-2020, 07:28 AM   #24
Werner
Werner's Avatar
Guten Tag!
Yes that's right. I swapped everything around the outside but the problem persists.
I also tried to find the cluster as a good used part, but unfortunately couldn't find anything. What I saw was no better than my own. Obviously the same problem everywhere is that the two gears for mediumspeed 2 are the most worn.
Werner
Citroen 11 CV, 1947
