Old 02-19-2020, 09:14 PM   #1
James G.
Default Hand throttle notches
My 31 Tudor has never been restored but well maintained. The body + interior parts are all original.
Problem - the notches on the hand throttle are pretty much worn flat.
What "make-do" repair can I do to make the control stay in one place while driving. I'd like to use it most when warming up the engine. But, maybe occasionally other times.
Is replacement the only possible solution? I really want to disassemble the steering assembly just to the the manual control working/staying in position.
All ideas greatly appreciated.
Jim G
[email protected] - if you want to chat about solutions.
James G. is offline   Reply With Quote
Old 02-19-2020, 10:06 PM   #2
whirnot
whirnot's Avatar
Default Re: Hand throttle notches
How badly is the rod worn. If it's just the plate. You can deepen the grooves with a three corner file. If the rod is worn as well, most are, then you are going to have to replace the rod and renew the plate.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 02-19-2020, 10:18 PM   #3
1crosscut
1crosscut's Avatar
Unhook the control rod at the firewall and then rotate the handle up so it goes past the plate it rubs against. Then gently push the handle forward to put just a bit more bend in it so it makes firmer contact against the plate.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 02-20-2020, 12:36 PM   #4
Farrell In Vancouver
Farrell In Vancouver's Avatar
The throttle and advance handles are held under spring tension at the lower end of the steering column. If the springs have weakened, the tension can be lost and the handle has no down ward push on the notched plate. I guess one could replace the springs with new ones, or insert some washers cut like a horse shoe to shim the springs for a better tension.
Farrell In Vancouver is offline   Reply With Quote
Old 02-20-2020, 12:37 PM   #5
5lugnuts
Will that work or break something? I have the same problem, but I have been reluctant to try bending the rod in place. Is this a common solution?
5lugnuts is offline   Reply With Quote
Old 02-20-2020, 12:55 PM   #6
Sunnybrook Farm
Sunnybrook Farm's Avatar
It seems the 2 tooth column controls wore down more than the 7 tooth that I have encountered. They must have made them feel easier to move when new and with a little wear they are loose.
Sunnybrook Farm is offline   Reply With Quote
Old 02-20-2020, 02:44 PM   #7
d.j. moordigian
d.j. moordigian's Avatar
IF you look at the back side of the rods where it touches the "V" notches,..they will be worn flat. That area is supposed to be round. Either weld up the originals and reshape
then replate...OR buy repops and hope they fit..
d.j. moordigian is offline   Reply With Quote
Old 02-20-2020, 05:38 PM   #8
mike657894
mike657894's Avatar
get some needle files and recut the grooves. https://www.amazon.com/Hardened-Stre...582238368&s=hi
mike657894 is offline   Reply With Quote
Old 02-20-2020, 06:04 PM   #9
ericr
ericr's Avatar
good topic, with no easy solutions. years ago I saw ads for services that would build up the bottom side with weld then replate it, but I have not seen that offered for a long time. I have read about fitment problems with the repros, as one member has said. As I recall the complaint was that the 90 degree bend was not defined enough
getting the lower springs on and off is challenging, as is replacing the anti-rattlers within the tube.
too bad the later columns did not use the replaceable quadrant that the earlier versions did.
ericr is offline   Reply With Quote
Old 02-20-2020, 07:40 PM   #10
whirnot
whirnot's Avatar
I replaced both of mine, last spring with new ones from Berts. They fit and work perfectly.
Bill Worden
1929 Roadster
1951 Ford F1
Old 02-20-2020, 08:18 PM   #11
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Keep in mind that they are spring loaded and can be pulled toward you to get some room to work with a file.
Jacksonlll is offline   Reply With Quote
Old 02-20-2020, 09:16 PM   #12
David R.
I had mine all apart. I built up the worn part on the underside of the spark and throttle rods with brass and filed them back to shape. I re-cut the quadrants with 3 corner file and reassembled with new springs.
David R. is offline   Reply With Quote
Old 02-22-2020, 05:13 PM   #13
Fullraceflathead
Fullraceflathead's Avatar
You can weld up the worn away area then carefully grind or file the raised edge to fit into the grooves.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-23-2020, 01:02 PM   #14
30 Closed Cab PU
If the rod springs are weak and or the grooves are worn, any issues caused if a second plate is added to the top of the old current plate?
30 Closed Cab PU is offline   Reply With Quote
