Old 12-29-2019, 04:29 PM   #1
Auto Anatomy
Default Dad’s 1928 Model A
Hello all,
About a year ago, my dad got bit by the Model A bug and picked up an early 1928 A. It was pretty complete but needed a little finishing up.
Here’s a photo of when it was picked up:
I’ve been videoing the journey of getting the car ready for regular usage and hope you enjoy.
Sean
Auto Anatomy is offline   Reply With Quote
Old 12-29-2019, 04:30 PM   #2
Auto Anatomy
Default Re: Dad’s 1928 Model A
Here’s a quick video of getting the car ready for winter driving, as well as a short drive.
Enjoy!
Sean
https://youtu.be/U6FhgedDmTQ
Old 12-29-2019, 06:20 PM   #3
mhsprecher
mhsprecher's Avatar
A good bug to get bitten by. Looks like a nice car.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 12-29-2019, 07:22 PM   #4
Bob C
That is a great looking car. I think it is a 1929 not an early 1928.
Outside door handles can out in OCT 28, Twolite headlights in Feb 29 and the
hand brake to the right of the shifter in July 29.
Old 12-29-2019, 07:25 PM   #5
Auto Anatomy
Good to know, I’ll let him know about the changes!
Sean
Old 12-29-2019, 10:45 PM   #6
California Travieso
Send a message via Yahoo to California Travieso
Sean,
Welcome to the Barn. I have a 29 Roadster also and they are fun.
You’re having fun driving the car. Looks like you might be getting the bug too!
David Serrano
California Travieso is offline   Reply With Quote
Old 12-30-2019, 11:44 AM   #7
katy
katy's Avatar
The horn bracket may be bent, as the horn appears to be angled up and should be angled down.
Old 12-30-2019, 11:52 AM   #8
Jeff/Illinois
Jeff/Illinois's Avatar
I have an A&L Sparton horn that has the same bent bracket issue. I need to use the original bracket. Not a big deal horn works fantastic
Sean, that is a VERY sharp Roadster thanks for posting and welcome to the hobby. I see you are in Colorado, you lucky Model A bum! Lucky in that you are close to Bert's in Englewood. They are super nice folks and can help you with ANY Model A Ford needs. Give them a holler they are one of the best in the USA. Here's a link for you and your Dad:
https://modelastore.com/
Jeff/Illinois is offline   Reply With Quote
Old 12-30-2019, 06:07 PM   #9
Dale G.
Dale G.'s Avatar
Katy,
Take a look at some books that show a lot of archive photos of Model A's and you will see that some horns project up and some project down right from the factory. Kinda like penises, some point up and some point down. That bracket that holds the horn is pretty tough steel and not likely to bend, the horn would bend first and break.
Dale G. is offline   Reply With Quote
Old 12-30-2019, 10:26 PM   #10
Auto Anatomy
Thanks everyone for the encouragement!
We love living in Colorado, as the weather is beautiful, the scenery is amazing, and the cars are (mostly) rust free!
As for the horn bracket, it probably is exaggerated in the pictures. In person it doesn't look off.
Sean
Old 12-31-2019, 11:28 AM   #11
dean from bozeman
dean from bozeman's Avatar
That's a very nice '29 Roadster, Sean.
The amazing thing about that heater is that the car went into "warp drive" once you got going. I'd like to get one of those. ;-)
You're only an hour or so from Bert's (in modern iron) and surrounded by many, many great Model A people. You and your dad will have great times ahead. Enjoy.
Dean
dean from bozeman is offline   Reply With Quote
Old 12-31-2019, 11:36 AM   #12
F.M.
Actually, The FIRST thing you should do is get rid of the FIRE looking to happen rubber hose on your fuel line to the Carb !!..
F.M. is offline   Reply With Quote
Old 12-31-2019, 12:34 PM   #13
Marshall V. Daut
Check your "Private Messages", upper right corner.
Marshall
Old 01-02-2020, 07:46 AM   #14
Auto Anatomy
Got a little more maintenance done on the Model A
https://youtu.be/03VEk_BQOc8
Old 01-02-2020, 11:08 AM   #15
jrelliott
jrelliott's Avatar
Welcome to Model A ownership. Enjoyed your videos. Luckily when I rebuilt my '28 Fordor, was a complete ground up so was able to get all the parts for brakes, steering, and drive train rebuilt before reassembly. Lot easier then. My build date was 9/11/28. Someone had changed the old multidisc clutch to the more modern one sometime before acquiring the vehicle in 2000.
jrelliott is offline   Reply With Quote
Old 01-02-2020, 12:31 PM   #16
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
I enjoy your videos.
FYI: The one piece front motor mount spring assembly that you removed from your car is not original. It can allow the front of the motor to sit too high and cause the hand crank to not fit properly.
Brattons sells the original type springs. See attached picture.
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 01-02-2020, 10:23 PM   #17
Auto Anatomy
We suspected that the mount was not original, but it’s all getting replaced as the engine was compressing the springs flat. On the side of the engine, it appears to have the Float a Motor style, but we’re replacing the front with an original style mount and replacing the yoke (since the original was worn).
Sean
Old 01-05-2020, 11:10 PM   #18
Auto Anatomy
Got the motor mount installed, nice to have the correct parts in place.
Sean
File Type: jpg D67E741D-9E30-40EB-98E8-6B86DE06828A.jpg (43.8 KB, 34 views)
