12-21-2019, 11:57 PM | #1 |
front timing cover
Note the timing cover on the right does not have a generator mounting pad and is missing the engine front mounting bolt hole on the right. This came off an engine that appears to have been in service in some capacity.
A close inspection reveals that the mounting pad and the bolt hole were very carefully machined off. The question is why would someone do that. It would seem that even if used in an industrial application it would need the right engine mounting bolt hole. The timing cover on the left is a normal cover. Tom Endy |
12-22-2019, 01:51 AM | #2 |
Re: front timing cover
Could it have been used in the aircraft version of the Model A Engine? Those engines used a Magneto and no front mount I believe.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
12-22-2019, 08:50 AM | #3 |
Perhaps an industrial application such as driving a commercial generator.
Bob Bidonde |
12-22-2019, 09:22 AM | #4 |
I don't know if Baldwin Gleaner made any changes for their combine application or not. There have been a number of industrial applications for the 200 cid Ford 4 cylinder.
Aircraft applications like the Pietenpol would have been modified by the owner/builder and most of them insist on driving the mag off the crankshaft with a flat plate fabricated into the timing cover. I would set one up to drive off the cam like they should be but each builder has the flexibility to set is up however they want since the Air Camper is an "Experimental" category home built aircraft. Last edited by rotorwrench; 12-22-2019 at 09:28 AM. |
12-23-2019, 12:33 PM | #5 |
