07-12-2018, 06:55 PM | #1 |
Bolts that hold backing plate 39 ford
Does anyone know of a vendor whom sells the original style bolts that hold backing plate to rear end. It’s a female style nut/bolt thing.
07-12-2018, 07:01 PM | #2 |
Re: Bolts that hold backing plate 39 ford
You may want to try Ray Helgers in RI 401 635 4849, or Fred Wilner at So Side Obsolete in Faribault MN 320 328 2756
07-12-2018, 08:32 PM | #3 |
111
07-12-2018, 08:33 PM | #4 |
what you have pictured is a tube nut used with an aftermarket tube shock installation kit. not original style. originally the 39 ford had a lever arm shock that bolted to the frame and the arm attached with a ball stud to the rear end. the backing plate had castle nuts with a hole in the stud for a cotter pin. you can try McMaster/karr hardware catalog, they may have such a nut.
07-12-2018, 09:38 PM | #5 |
Roy Naceawitz
07-13-2018, 05:37 AM | #6 |
07-13-2018, 08:19 AM | #7 |
Rusty: The bolts you show look like after market tube shock bolts used on backing plate.
You can see the sleeve and bolt here. Car is 40 Ford. Last edited by 19Fordy; 07-13-2018 at 12:48 PM. |
07-13-2018, 08:49 AM | #8 |
From the information posted by the O/P, I agree with "alanwoodieman".
07-13-2018, 08:56 AM | #9 |
he had pictures posted on the V8 website, go look if you can
07-13-2018, 09:24 AM | #10 |
This is what he had posted.
Bob |
07-13-2018, 03:37 PM | #11 |
The bolt is the original long bolt that is used in the lower two holes and normally go through the radius arm. The nut is a special, used with a tube shock conversion. The bolt will take a standard castellated nut if the shock conversion is not required.
07-13-2018, 06:55 PM | #12 |
Both the long bolt and special nut are specifically for the aftermarket lower shock brackets the bolt to rear end through the backing plates, wishbone and axle itself. Please let us know if you find some as they are pretty scarce. Mike Driskell may have some at 3rd gen automotive 35fordtn here on Fordbarn
07-13-2018, 10:22 PM | #13 |
This is for a 36 Ford but can you believe the price?
https://www.ebay.com/itm/1935-1936-F...itleDesc=0%7C0 |
07-14-2018, 12:32 PM | #14 |
Must be a Corvette guy.
07-14-2018, 02:51 PM | #15 | |
07-14-2018, 03:57 PM | #16 |
Thanks for the info. You guys are spot on as always. The 1937 I just bought has had the brakes converted to 1939 hydraulics. It also has one of the tube shock conversion kits on it. It is missing one of these female type nuts. I will make some phone calls to try and locate one. I do have a machinist friend who says he can make me a few. Might have to go this route.
07-14-2018, 05:17 PM | #17 |
I remember modifying a mag wheel type lug nut to do the same job.
07-14-2018, 05:47 PM | #18 |
What thread size is it ? I've used 3/8 fine poly lock nuts for small block Chevys and 7/16 poly locks from big block Chevy valve train . For similar fixes , though not this application.
They're about 1" long . |
