02-17-2016, 07:54 AM | #1 |
How do Wheel Bearings Survive?
There has been much concern expressed about using grease to pack the U joint housing, and putting grease in the steering box. The thought being the grease will be pushed aside as soon as the parts move, then the parts will run with no lubrication.
If this is so, then wouldn't the same thing hold true for the front wheel bearings? The hubs have a large cavity for the grease to be pushed into and away from the rollers. I won't be pulling my rear axle anytime soon, but when I do I'll have to take a picture of the U joint to see how it survived the Mystik JT6 grease. My steering gear leaks out the 600W within a few days, so I pump in grease then add some gear oil. Any lubrication is better than no lubrication, and Mystik is a very stringy grease that clings to parts. Several riding lawn mowers have 5 or 6 speed aluminum case transmissions with no fill or drain plugs. They are packed with grease when assembled, then left to do their job. Does anyone know the recommended grease for these? I'll call a lawn mower shop later and see what they recommend. |
02-17-2016, 08:05 AM | #2 |
Re: How do Wheel Bearings Survive?
I saw on You Tube where someone was repacking the front wheel bearings . The wheel bearings were then adjusted with zero play, a sure way to ensure limited lifespan . Oddly the spindle seemed to be left hand thread I have not seen that on a Model A .
John in sunny morning but rain on the way Suffolk County England |
02-17-2016, 08:10 AM | #3 |
Tom, I was under the impression that most grease has a viscosity rating similar to oil, where once it warms up it will flow to some degree. I know if I use half a tube to pack wheel bearings, 6 months later (give or take) when I have to do another, the grease that was left on the sides had "run" to the bottom of the tube.
I just picked up a tube of JD corn head grease yesterday, and according to the label, it's just a thinner version of the same JD polyurea grease I already use Looking for the front bumper emblem that has "Ford, Made In Canada" |
02-17-2016, 08:13 AM | #4 |
Wheel bearing grease will withstand the heat generated by the brakes and friction created by the bearings. Packing the bearing rollers properly is essential, as the grease will stick to it and lubricate the bearings... Only the residual excess will get thrown off...
Regarding what does get thrown heat will also cause it to liquify to some degree and drip onto the moving components in the u-joint cavity Last edited by Mitch//pa; 02-17-2016 at 11:07 AM. |
02-17-2016, 08:20 AM | #5 |
Grease liquefies when its temperature rises in a bearing, and has squeeze-out resistance.
Bob Bidonde |
02-17-2016, 08:51 AM | #6 |
02-17-2016, 09:30 AM | #7 |
Take some of your grease and put it in a tin can then put it on the stove, I think you will be surprised of how much heat it can take before you see any softening of the grease.
I like Lucas red and tacky #2 grease. I always use a bearing packer on tapered roller bearings. carry on nick c |
02-17-2016, 10:36 AM | #8 |
The LONG life of Timken Wheel Bearings is like a MIRACLE!!
BUT, ALWAYS use a Quality Brand, HIGH TEMP, Disc Brake Grease!!!! All wheel bearing greases are NOT EQUAL!!!! Seriously, I've done this stuff for YEARS & I'm NOT just whistlin' "DIXIE"!!! I've seen a lots of FAILURES, from using "ACME" Brand greases. Loosely adjusted bearings will NOT let the ROLLERS do their job of CIRCULATING the grease!!! A proper packing job will go 30,000 miles, with a quick re-adjustment at 15,000 miles. Bill W.
02-17-2016, 10:49 AM | #9 |
"Back in the day" the wheel bearing grease I used had lots of long stringy fibers in it. As far as I know, there isn't anything close to that today. I thought I had struck the motherload when I found some Timken Wheel Bearing Grease, only to find that it looks just like Tom's Mystic grease, which is what I use everywhere else.
02-17-2016, 11:04 AM | #10 | |
Bill Old
02-17-2016, 11:08 AM | #11 |
I know it is according to how much you drive but is there a good rule of thumb on re-packing the wheel bearings. I will be taking my 31 s/w to the Cigar City flatheads Barners Bash Cruse March 3rd 4 & 5th. an was just wondering.
02-17-2016, 11:21 AM | #12 |
02-17-2016, 12:09 PM | #13 |
Howcum taper roller bearings in the rear axle are preloaded while the ones in the front wheel hubs are adjusted very slightly loose, w/out any preload?
Does the fact that the rear axle ones are running in oil while the front wheel ones are in grease come into the equation?
02-17-2016, 12:16 PM | #14 |
When I finally used up my bucket of Texaco Marfak "O" grease I couldn't find anything like it available. Anything dipped in that stuff came out trailing a foot long string - now that is sticky!
02-17-2016, 12:19 PM | #15 |
You guys are all wrong! The answer to Tom's question is "friggen magic". The answer to katy's question is the hubs expand and tighten the bearings.
02-17-2016, 12:20 PM | #16 | |
02-17-2016, 12:25 PM | #17 |
I've used Mystik grease for years. I bought it at my local wall mart. But now they don't sell it any more . they have Lucas instead. How does Lucas compare to Mystik? None of my local auto stores handles Mystik either.
I've been doing so much for so long with so little that now I can do almost anything with nothing. |
02-17-2016, 12:33 PM | #18 |
Your local O'Riley store should carry Mystik. That's where I get it here.
02-17-2016, 12:35 PM | #19 | |
This sounds like what Larry Jenkins was talking about, jeez
02-17-2016, 12:42 PM | #20 | |
