02-07-2014, 04:36 PM | #1 |
Valve Guides-tight fit?
Whats the solution to tight valve guides-split-stock. Won't seat all the way down? thanks.
www.whidbeymodelaclub.com |
02-07-2014, 06:19 PM | #2 |
Re: Valve Guides-tight fit?
Gary I always freeze them before installation
02-07-2014, 07:20 PM | #3 |
Last summer when I was cleaning my block I cleaned out the guide holes with a battery terminal cleaning brush, there was a very thin layer of something in there.
02-07-2014, 07:27 PM | #4 |
Good Ideas above Thanks for the tips.
02-07-2014, 10:16 PM | #5 |
I was thinking BFH, but the other ideas are probably better.
02-07-2014, 11:16 PM | #6 | |
Those brushes plumbers use on copper pipes work good, also, & come in different sizes. Bill W. (The Dog tole me to tole you thet thet layer of "something" wuz CRUD!)
02-07-2014, 11:28 PM | #7 |
Mic the O.D. of the guides, as some are not made to Spec's. Some are as much as .002 thousandths bigger then they should be.
I have had to buy as many as 3 sets and pick out the good ones, and send the rest back! |
02-08-2014, 12:48 AM | #8 |
Bill, yes the plumbers brush would be perfect, it has a longer handle. (Please tell Dog thanks for the technical description).
02-08-2014, 03:19 AM | #9 |
Herm is right of course, but I still like the BFH idea when all else fails. The good thing about the BFH idea is that you can use it when you do not mic the guides to specs as Herm suggests, and then the guides compress when you get them in, and bind on the valve stems....which you have measured for fit....Moral is, measure everything, twice.
