02-06-2014, 02:57 AM | #21 |
Re: Best overdrive
02-06-2014, 06:52 AM | #22 | ||
Re: Best overdrive
It is personal choice, your comfort level, it's your car, keeping them original is a great goal. But there is a lot to be said for overdrive, synchromesh transmission shifting, the ability to coast without engine brake if wanted. Etc.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
02-06-2014, 08:51 AM | #23 |
Re: Best overdrive
I like the Mitchell best. Really bolt on unit and after you have driven a short time you will realize it makes your car operate like it is fully syncro trans. F 150 unit like Gary Bernard and MR ken parker install are great but 1st gear is lower than orig. trans . You can replace the car bell housing and use the AA bellhousing and not cut the small gap in brake unit. I am originally from Dallas,TX area and in 2003 talked to Gary about his unit because I didn't want the extra shifter that the Mitchell had. Told Gary I was going to have car in GREAT RACE and that stopped everything cold. Gary had been trying to get the 4 speed ok'd for 3 years in the race and owner of race Tom MC rea [sp] always said no. This is the reason I went with Mitchell , I was also running 3.27 gear since 2001. Mr Mitchell thought it would be to high of gear but I knew my car and it's great wouldn't change anything. You can also get different gearing use just ask for it. Check out my avatar info for car performance. have fun modelAtony Lafayette,la
02-06-2014, 08:59 AM | #24 |
Re: Best overdrive
I concur with Tom Endy that the Mitchell is the preferred way to go, 26%. You essentially have 6 forward speeds if needed for various driving conditions..... and it is a well built unit that will give years of service. It gets the engine RPM's down to a comfortable level for highway cruising. My '30 Tudor has an older Ryan ( Mitchell was just coming out then) and at 23% plus I kept my 3:54 it does well on the highways with a HC head. I have driven Pikes Peak with it and many mountain passes in Colorado.... and the additional gearing makes it nice.
As with any car... you have to know your car, gearing/load/when to shift... do not lug... etc As Tom says the cost of the overdrive adds value to the car as a tour car if a sale is desired. I have installed Mitchells and all have gone well. They are a bolt up install except for the floorboard cut. Larry Shepard |
02-06-2014, 10:42 AM | #25 |
Re: Best overdrive
With a Mitchell, you don't have to have an extra shift lever coming through the floor, as there is a sturdy cable operated option. If you're gonna run this set up in a speedster or a severely lowered car you will have to turn the cable lever on the O'D unit upside down and mount the cable from the rear to get clearance to the floor.
02-06-2014, 11:11 AM | #26 |
Re: Best overdrive
Blackwall Panthers Nor Cal chapter |
02-06-2014, 02:48 PM | #27 |
Re: Best overdrive
I know many happy Model Aers who have the Mitchell OD. They are very well made and are good units. However, I have the Laycock (Volvo) OD in my coupe. I love it for two reasons. First, the price is less expensive the Micthell. And second, the ease of shifting the unit in and out of overdrive. It can be shifted without engaging the clutch and it is operated with a toggle switch located under the gearshift knob. It also does not take up any valuable floor space. JMO
02-06-2014, 03:15 PM | #28 |
Re: Best overdrive
I installed a Mitchell on my own as a Rookie (with only a little help from the local shop to get the pinion gear onto the Mitchell shaft). It was undoubtedly the best modification I made to the car. I drive about 300 mi / week, about half of them having to be on the Interstate. Before I had the Mitchell, I rarely could stay above 55, and was revving the engine so hard it was painful and embarrassing to listen to.
Also, when climbing hills here in Northern California, the 2 1/2 gear is essential - there is just too much gear ratio space between 2nd and 3rd when climbing these hills. |
02-06-2014, 05:50 PM | #29 |
Re: Best overdrive
Lots of folks run f-150 and love um . Me for one .
02-06-2014, 06:02 PM | #30 |
Re: Best overdrive
I have the 4-speed from Gary Bernard. I absolutely love it. It's fully syncro so no worries about grinding gears. I had a worn out transmission anyways, so when going for an overdrive it was a no brainer to just get the 4 speed. I do however miss the whine of the Model A transmission. If the transmission is good in my next car, I'll get a mitchell so I can have the best of both worlds.
Cowtown A's |
02-06-2014, 08:41 PM | #31 |
Re: Best overdrive
I love my Volvo!
02-06-2014, 10:04 PM | #32 |
Re: Best overdrive
I made up a chart of engine RPM vs car speed before I changed my trans to a f150 trans. I used the small V8 gearing to 1st gear as low numerically (3.01:1) as possible. Trans code AK.This is based on using 16" radials on my car. With a .100 over engine and 7.5:1 head, there is no problems in using OD even at 35 mph. This is a full pressure inserted engine. And no, I don't try to climb steep hills in OD!
1965 Lotus Elan S2 1930 Model A Sport Coupe |
02-06-2014, 11:13 PM | #33 |
Re: Best overdrive
. However Ford did the original factory crank/flywheel balance no one seems to be able to duplicate it today. ---when many machine shops have the attitude that it is just an old car, it won't matter it's hard to get anything done to oe specs
Plus the universal joint is a single joint, not one on each end of the drive shaft as was done later. Thus there is a constant fast/slow component to the rotation of the driveshaft The angle of the engine nearly matches the angle of the driveshaft, not enough of an angle to be a factor. Plus there were few roads where you could actually accomplish 60 mph back then, unless you were on a track, so to me the 60 mph was a lot of hot air to accomplish some nifty advertising. --from the may-june Model A News -in 1933 a model a with 62,000 miles averaged 62 mph traveling from LA to Phoenix, and on the return trip averaged 60, previous to this they did 500 miles on the salt flats at 66.66 mph average speed (It must have been a wild ride for the observer in the back seat) If there are any Barners who have driven stock Model As out there at 60 mph for thousands of miles without engine damage let them come forward. To me, a stock A redlines at 2000, maybe 2200 rpm. I never run mine over 2000. (I have a full time tach). --- On the 3rd day of driving the freshly done babbitt I knew that the car would show 67 on the speedo, but I tried to keep it under 60 for the next 1000 miles, on the way home I tried to break it, rarely under 60, PA turnpike at 65(averaging 23 mpg), 2000 miles more ----I don't know how many more miles. I used to unhook the cable so my parents didn't know how far I drove I want my babbitt to last a good long time. Choose your priorities, do your research, and make your choices accordingly. -- When my car was first restored with a professionally rebuilt engine I rarely got over 50,drove it easy-- that job only lasted 3000 miles before the babbitt crumbled ---so I figured that I couldn't do worse doing it myself, I have spent the last 25 years trying to break it, even though I know that I have a flywheel/crankshaft balance problem ---the only thing I have broke is the babbitt on 1 rod, one I shouldn't have used when I put the engine togewther, but it was closest to the other 3 in weight---and yes I was going above 65 when it came apart--but being babbit it did no damage to the crankshaft, and i drove it home after it happened. And all this in responce to a first time post by someone that just wants to go "near highway speeds "---over 30 posts about overdrive. I think I am getting closer to breaking my engine, the flywheel vibration is getting a little more pronounced, from the beginning the car would move in a circular motion going through 8-900 rpm, I know the crankshaft was ground .003 off center, it was the first time I poured babbitt and I have figured how can I know how good I did if i didn't try to break it, I have run the car in a circle for over 1 hour at idle in 3rd on a 95 degree day, lugged it through deep sand, left it at full advance for most driving, some of the oil changes were done with used oil, and I have come to the conclusion that there is not much you can do to save bad babbitt, and conversly that there isn't much you can do to hurt good babbitt. I also feel that proper restoration to original specifications and tolerances will eliminate the need for most modifications in normal use If I was to install an overdrive I will use a Columbia because it is the cheapest option for me |
