Old 08-29-2020, 08:58 AM   #1
springerpete
springerpete's Avatar
Default front tire wear
On a friend's '29 roadster the right front tire shows significant wear in the center and towards the outside of center. Outside tread is OK. Checked the toe in and it is 1/16" + so that is good. Left front tire is OK. Suggestions as to his problem ? Thanks. Bill
springerpete is offline   Reply With Quote
Old 08-29-2020, 09:55 AM   #2
katy
katy's Avatar
Default Re: front tire wear
Check the camber on that wheel.
Old 08-29-2020, 10:17 AM   #3
Mulletwagon
Mulletwagon's Avatar
Center wear often indicates over inflation. Is the pressure around 35 psi ?
Mulletwagon is offline   Reply With Quote
Old 08-29-2020, 10:38 AM   #4
Patrick L.
Patrick L.'s Avatar
What kind of wear ? Any feather-edge or scallop ?
You can look from the front of the car and see the camber, but, it doesn't really sound as though you have a camber issue.
1/16" of toe-in is OK.
I too was thinking tire pressure. 35# is correct.
It could also be a bad/defective tire.
Old 08-29-2020, 02:05 PM   #5
Charlie Stephens
Sounds like too much pressure to me, is the gauge accurate?
Charlie Stephens
Old 08-29-2020, 02:34 PM   #6
McMimmcs
McMimmcs's Avatar
We've all seen over inflated centre wear, check it first !
Old 08-29-2020, 05:22 PM   #7
Werner
Werner's Avatar
Pete,
heavy tire wear on the outside indicates that the toe-in is too large. But then correctly on both sides.
If only one side wears on in or out side, this is an indication that something is warped on the suspension.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-29-2020, 09:59 PM   #8
Jim/GA
Jim/GA's Avatar
Originally Posted by Werner View Post
Pete,
Yes. Bent axle. Common on the right side.
Jim Cannon
"Have a Model A day!"
Old 08-30-2020, 06:40 PM   #9
Synchro909
Synchro909's Avatar
I agree - the axle needs a tweek but obviously, it is the LHS that is more commonly bent here. (The kerb side)
