Old 08-14-2020, 05:13 AM   #1
DBSHELTON
Default Cam Choice
Putting together a motor for my Huckster. Lion Speed 7:1 head, B distributor Vortex intake, dual Tilly carbs, lightened flywheel, V8 clutch, 3.78 rear, straight thru muffler and 2" tailpipe. Have a B-W overdrive that I may install. What regrind cam is recommended? Maybe one of Jim's C grinds?
DBSHELTON is offline   Reply With Quote
Old 08-14-2020, 06:30 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Cam Choice
Originally Posted by DBSHELTON View Post
Putting together a motor for my Huckster. Lion Speed 7:1 head, B distributor Vortex intake, dual Tilly carbs, lightened flywheel, V8 clutch. What regrind cam is recommended? Maybe one of Jim's C grinds?
You did not mention gear ratio or exhaust system which will factor into your decision.
IMO, any advice you receive here is just based off of speculation since it is unlikely that anyone actually has your exact engine combination and vehicle weight. Since Bill Stipe and Jim have likely dyno-ed their own cams with different engine combinations (-I know Bill has), I would make my final decision based solely off of their recommendations.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-14-2020, 07:25 AM   #3
DBSHELTON
Thanks. I did send Jim a PM and hope to get a response. Edited for more info.
Old 08-14-2020, 07:53 AM   #4
Jack Shaft
The camshaft choice is critical,it sets parameters your other performance parts operate under. Cam choice can greatly affect driveability,part of the parameters it sets is when torque rolls on,cams for pure racing are difficult to street drive with.Cam cost needs to be mentioned as well,new cams run north of four hundred dollars,where regrinds run south of 200.Regrinding A and B cams is viable,they have enough 'meat' to work with.As for spec'ing what you want speaking to cam grinders is important.
I can tell you what I did,my goal was to double the power of the model and keeping it a flathead for street driving.My car is on the light side,a sport coupe.
Winfield 7 to 1 head
Single down draft 94
reds 4 into 2 header y'ed to a resonator
B distributor with 35k voltage coil
mitchell 26% OD,3.78 rear ratio
I found a really good late B profile high measured lift cam in an engine I bought at a farm auction,measured lift is .319,the B cam came .302 lift too.The B profile allows for a smooth idle yet allows for a higher rpm and torque rise..I'm very pleased with the street performance.I can drive in low range like a stock A and use low shift points,or wind out 2nd low and 2nd high range and perform with modern traffic.
Old 08-14-2020, 09:43 AM   #5
Jim Brierley
DB, got your PM, and freplied. Stay on the mild side for touring. My 'C' grind is a copy of the latest B cam, mine has .320" lobe lift and slightly more duration than earlier B's.
Old 08-14-2020, 10:34 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
I run a Winfield 3/4 race grind from Bill Stipe , It idles good and improves overall performance .
Old 08-14-2020, 11:42 AM   #7
Big hammer
How about larger valves ?
get a bigger hammer tap done
Old 08-14-2020, 11:56 AM   #8
DBSHELTON
No, stock size valves.
Old 08-14-2020, 07:11 PM   #9
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
You will like Jiim's "C" grind cam. I do.
Never been accused of holding up traffic either.
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 08-14-2020, 07:51 PM   #10
Synchro909
Synchro909's Avatar
I run a cam I have done locally. It is a new grind put on an original A camshaft - not a new one so it is very economical.
Duration is 264 degrees which is significantly more than any of the B profiles but the lift is a modest 0.288". My best engines run that cam with a 5.5 head and downdraught Stromberg (ex Holden grey motor) carburettor. It is with this setup I tow a camper weighing about a tonne behind my Phaeton all day long for days on end at 50 mph. I love driving this car solo too. It surprises many a modern motorist. Can't get the grin off my face even now!
Old 08-18-2020, 05:57 AM   #11
DBSHELTON
I think I will go with Jim's "C" grind.
Thanks for all the input.
Old 08-22-2020, 03:13 PM   #12
DBSHELTON
Damn these old head studs can be a PITA to remove!
Old 08-23-2020, 10:28 AM   #13
Purdy Swoft
Just wait until the studs start breaking off in the block . This has often been the problem .
Old 08-23-2020, 02:40 PM   #14
DBSHELTON
Yep, I broke 3 off in the block. Had to drill out and Helicoil them.
Old 08-23-2020, 07:31 PM   #15
Gene F
Gene F's Avatar
What studs?
