Old 05-05-2019, 09:36 PM   #1
michael a
michael a's Avatar
Default No start
Engine cranks but doesn't fire until I release the starter. 6 volt pos. Ground.
Sent from my SM-J701M using Tapatalk
michael a is offline   Reply With Quote
Old 05-05-2019, 09:47 PM   #2
eagle
eagle's Avatar
Default Re: No start
Put a ground strap between engine and frame. Check point gap.
Old 05-05-2019, 09:53 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
A defective battery will not provide enough voltage to run the ignition and the starter. Once the starter is off the voltage goes up and the coil fires before the engine stops turning over.
Clip a meter to one of the nuts on the terminal block and measure the voltage with and without the starter running, should be only a small amount of difference.
Old 05-05-2019, 10:28 PM   #4
Charlie Stephens
Did you modify the wiring by adding a resister that is bypassed when starting? If the answer is yes check the resister and the connections to it.
Charlie Stephens
Old 05-05-2019, 11:24 PM   #5
michael a
michael a's Avatar
No sir I did not. However my battery shut off is on the firewall and all the electrics is on the starter side of the switch. I realize it should be on the ground cable but it was that way when I got the car
Old 05-06-2019, 07:37 AM   #6
rocket1
Check the polarity of the coil,usually will work either way but better if correct.
rocket1 is offline   Reply With Quote
Old 05-06-2019, 08:32 AM   #7
ryanheacox
ryanheacox's Avatar
I second the weak ground theory
Old 05-06-2019, 08:45 AM   #8
johnneilson
It could also be the battery shut off switch is deteriorating.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 05-06-2019, 08:52 AM   #9
30 Closed Cab PU
Do you have modern wireless distributor plates? I had the wireless Nurex plates, sometimes was hard to start amongst other symptoms. Finally replaced with original design plates and all issues were solved.
Old 05-07-2019, 07:23 AM   #10
chap52
chap52's Avatar
John
Bypass that cut-off switch and see what happens. Chap
