Old 08-03-2021, 09:41 PM   #1
Bud
Bud's Avatar
Default Rumble and Trunk Lid Handle Locations
Hi, for a 30-31 Rumble Lid versus a Trunk lid: What is the dimension from the edge of the lid to the handle hole?
Can anyone confirm that for the Rumble lid the dimension from the top edge to the center of the hole is 2.75"?
Can anyone confirm that for the Trunk lid the dimension from the bottom edge to the center of the hole is 1.75"?
If these are incorrect dimensions, please provide the correct dimensions.
Thank you!
Bud is offline   Reply With Quote
Old 08-04-2021, 01:40 PM   #2
Randy in ca
Randy in ca's Avatar
Default Re: Rumble and Trunk Lid Handle Locations
My rumble handle is closer to 2 - 5/8" from edge FWIW.
Randy in ca is offline   Reply With Quote
Old 08-04-2021, 01:57 PM   #3
ursus
My '31 trunk handle is 1.75" from edge to the hole center.
ursus is offline   Reply With Quote
Old 08-06-2021, 07:05 PM   #4
Bud
Bud's Avatar
Thanks, that helps.
Old 08-06-2021, 08:33 PM   #5
Kevin in NJ
Use the latch to get the exact dimensions.
The hole needs to be placed to match where the latch position will be. It is important to note that the collar of the latch MUST touch the underside of the rumble lid panel. Otherwise the handle will pull the outer sheet metal down causing a low spot.
Kevin in NJ is offline   Reply With Quote
Old 08-10-2021, 10:58 AM   #6
gdmn852
gdmn852's Avatar
Hello mine is about 1 1/4 inch from edge,31 roadster but I don’t think it is original to the car .
File Type: jpeg B7C445B8-ADDD-4483-B9E1-1C2A5EAA0D43.jpeg (76.3 KB, 5 views)
gdmn852 is offline   Reply With Quote
Thread Tools
Display Modes
