Old 07-24-2020, 01:32 AM   #1
7_Zero
7_Zero's Avatar
Default Help diagnosing engine knock
I realize it is difficult to diagnose through text, but I am hoping to get some ideas of things to check before digging deeper into it.
I recently purchased the car and the engine was supposedly rebuilt maybe 10 or 15 years ago. Based on some pitting in the valves I am wondering if it was more of a refresher than a complete rebuild. The previous two owners did not drive the car much and there are only 550 miles on the odometer, so I am assuming it only has that many miles since the ‘rebuild’ but we know what assuming does.
We drove the car around town for a couple weeks before taking it on a long trip and had no problems. On the trip however it started blowing radiator hoses (it has a pressurized radiator). After installing the third hose we watched for bubbles in the radiator and determined it to be a head gasket allowing combustion gasses to pressurize the cooling system. When we had the head off we decided to go with a 5.5:1 head, but unfortunately after the install the engine now has a knock.
The knock is audible at idle and when the engine is revved. You can hear it with the spark advanced or retarded. With or without the fan belt, clutch engaged or disengaged, and has no difference when disconnecting each of the spark plugs. Reversing the timing pin and putting pressure on the timing gear also yields no change.
Using a stethoscope, the sound is loudest at the front of the engine especially around the timing cover, timing pin and cam plunger area. Not sure if the knock has to do with the timing gear and cam, or if it is in the front main and only echoing through the timing cover? The engine had a two piece pulley that we originally thought was the cause so we replaced the pulley and also replaced the cam plunger and spring, but unfortunately it made no change.
Any suggestions on additional things to check, or is it just time to dig in to the bottom end?
Thank you for your help!
7_Zero is offline   Reply With Quote
Old 07-24-2020, 01:44 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Help diagnosing engine knock
Perhaps it has a larger bore and pistons hitting edges of head gasket, how did old head gasket compare to old one
Old 07-24-2020, 05:08 AM   #3
Wick
Wick's Avatar
Witch head gasket did you use?
Wick is offline   Reply With Quote
Old 07-24-2020, 07:33 AM   #4
Jack Shaft
Pull pan and check bearings,verify they are ok.
Jack Shaft is offline   Reply With Quote
Old 07-24-2020, 08:03 AM   #5
Nosetime
Nosetime's Avatar
Did you verify piston pop up and gasket clearance? Pull head and check.
Nosetime is offline   Reply With Quote
Old 07-24-2020, 08:05 AM   #6
1931 flamingo
1931 flamingo's Avatar
Disconnect the fan belt and try again, use a long screwdriver or broom stick as a stethascope.
Paul in CT
Old 07-24-2020, 08:44 AM   #7
30 Closed Cab PU
Perhaps possible the higher compression head and a new head gasket has increased compression to the point where it is time to check/adjust bearing clearances?
30 Closed Cab PU is offline   Reply With Quote
Old 07-24-2020, 09:20 AM   #8
katy
katy's Avatar
It could be a piston hitting the head. The test is to put the head on the block w/out a gasket and turn the engine over by hand to see if any of the pistons hit the head.
Old 07-24-2020, 10:38 AM   #9
PC/SR
Agree with Nosetime and katy, could be hitting the head. Use Prussian Blue to check popup, gasket and side interferance. Similiar thing happened to a friends car. He ran it and broke the crankshaft. Might also try just laying the head in place without bolting down and see if it moves on rotation.
PC/SR is offline   Reply With Quote
Old 07-24-2020, 12:16 PM   #10
Ernie Vitucci
Good Morning...Katy is most likely right. If the original head is nice and flat, put it back on the car with a fresh gasket and see if the knock goes away. Were you able to see that a head gasket failure was the cause of the exhaust in the radiator? If so, then your number one piston is most likely tapping the head. When you remove the 5.5 head you should be able to see the evidence on the piston and on the head. Or maybe on the edge of the gasket, but it is most likely the piston to head contact. Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 07-24-2020, 04:06 PM   #11
Dave N.
I can only offer my life lesson for my engine knock, but raise the distributor up from the new head about an 1/16 to 1/8 of an inch and than tighten it up again.
Dave N. is offline   Reply With Quote
Old 07-24-2020, 06:24 PM   #12
Synchro909
Synchro909's Avatar
When I took delivery of my 1928 Tudor from the US, I didn't know the engine had had a "freshen up". The job they did on it was pretty lousy and when I put a 5,5 head on it, I too got a knock from it (sound familiar?). I stripped the engine and found 0.005" over sized gudgeon pins had been installed. This was done by either reaming or honing the bushes to suit, only they went too far and they were loose, causing the knock. A new set of bushes properly installed all is good now. It may be worth your while checking them.
BTW, the bronze they use in those small end bushes is nearly impossible to ream - terrible stuff.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-24-2020, 08:12 PM   #13
noyo55
Back about 50 years back I had a similar knock--constant. Turned out a chunk came off the timing gear. It sounded just like a rod knock but was consant.
noyo55 is offline   Reply With Quote
Old 07-24-2020, 08:26 PM   #14
darrowco
I vote for checking the piston/head clearance. I had a similar knock and traced it down using an accelerometer and an oscilloscope - the knock lined up perfectly with the exhaust stroke of #3. At that point, I realized that the recently skimmed head had gotten one skim too many. The engine turned over freely by hand - the knock only occurred when the piston was flung up while running and took up the slack. Once apart (for the 3rd time) the mark on the head was beeeaaarly visible. A little relief cutting in the head solved the problem.
darrowco is offline   Reply With Quote
Old 07-25-2020, 12:40 AM   #15
TerryH
TerryH's Avatar
I also had a faint knocking sound that none of my Model A friends or I could identify. It ended up being a fiber timing gear going bad, which eventually failed. New gear installed and the noise went away.
TerryH is offline   Reply With Quote
Old 07-25-2020, 06:22 AM   #16
fundytides
fundytides's Avatar
The engine in my car was "rebuiltl" back in the 60's but never run. When I started running it recently, it seemed quite noisy to me. At first I suspected an oil pump problem but I removed the plug on the side of the block and there is lots of oil flow. The engine has .125 oversize pistons. Would the gaskets available then have accommodated this oversize? Can I tell if the pistons are hitting the gasket or head without removing the head. The head was probably planed at the time as well. I am going to remove pan to check rods and also check valves for proper clearance. To me it is more of a "clatter" than a knock. All suggestions are appreciated.
fundytides is offline   Reply With Quote
Old 10-25-2020, 04:19 PM   #17
7_Zero
7_Zero's Avatar
Thank you all for your responses, I apologize it has taken so long to reply, things have been quite busy and I have not had a chance to work on the car.
I believe the pistons are .060 as they are stamped 060-C. We used a Best 509 head gasket. The new gasket and old gasket appeared similar in size around the piston side of the engine, but the area by the valves and between cylinders was quite narrow on the new gasket.
I did not verify piston pop up and gasket clearance, unfortunately this never crossed my mind as this is our first head gasket change.
Paul in CT
Unfortunately this made no difference.
Originally Posted by Ernie Vitucci View Post
... Were you able to see that a head gasket failure was the cause of the exhaust in the radiator?...
There was no major blowout in the head gasket, just a couple dark areas. We are thinking that since the previous owners did not drive it much after the rebuild that the head just did not get retorqued.
Raised the distributor and no change, re-seated it, still no change. But it did make a difference on our other car.
Originally Posted by Synchro909 View Post
... I stripped the engine and found 0.005" over sized gudgeon pins had been installed. This was done by either reaming or honing the bushes to suit, only they went too far and they were loose, causing the knock. A new set of bushes properly installed all is good now. It may be worth your while checking them....
Any way to check the gudgeon pins without doing a full teardown?
This is one possibility that we were hoping it would be, but the timing gear looked good. Not saying we did not miss something though.
Here is a link to a couple videos.
When running at higher rpms it is harder to hear, there are distinct knocks at the 8-9 second mark and again at 14-15.
We have just acquired a head puller so we can start working on this again.
Thanks!
Old 10-25-2020, 04:39 PM   #18
Patrick L.
Patrick L.'s Avatar
If you want to check the clearance between head, gasket and piston, just use some modeling clay.
Old 10-25-2020, 04:55 PM   #19
Synchro909
Synchro909's Avatar
I did mine by taking off the head and sump, then pushing the pistons and rods up through the bores and out the top so yes, you don't have to do a full tear down. Rod bearings (and mains) would be checked at the same time. All that said, check the easiest things first.
Old 10-25-2020, 05:02 PM   #20
John
John's Avatar
Do check the piston to head clearance. A local club member recently installed a rebuilt engine with a new high compression head and had a similar knock. It turned out that the head was incorrectly machined and did not have the proper piston relief for his engine.
John is online now   Reply With Quote
