Old 01-03-2012, 09:33 AM   #1
Kurt in NJ
Kurt in NJ's Avatar
Default Aftermarket brake drum
I bought this drum many years ago because it was near standard size, and the metal is thicker than an original drum--about 25% -----but it is the only one I have ever seen.
The dimples on the outside are on the inside too. ---I don'r know if they are an improvement or just dirt catching squeak starters.
There were many aftermarket companys making parts, some better, most worse than Ford parts
Old 01-03-2012, 10:25 AM   #2
Jim Parker Toronto
Jim Parker Toronto's Avatar
Default Re: Aftermarket brake drum
Interesting, any pictures of the inside?
Jim Parker Toronto is offline   Reply With Quote
Old 01-03-2012, 09:16 PM   #3
oldscout
I have 4 of them on the car, they relined the inside of the drum, held with the rivits, then cut the heads off the inside. My rears are 10 and 15/16 inches inside diameter and the new shoes won't fit. Take a look at the back side and you should see a seam between the drum and the liner.
oldscout is offline   Reply With Quote
Old 01-03-2012, 10:54 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
This drum is formed that way, there is a matching dimple inside the drum --it is a1 piece stamping ---no rivits or liner, it is at 12.010--15 ---a little out of round
Old 01-03-2012, 11:43 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
12" That's 1" larger than the Model A. That is a strange looking drum and I've never seen one like it.
Old 01-03-2012, 11:52 PM   #6
Jim Parker Toronto
12" would mean it is Model B..... Not A
