Old 12-30-2019, 08:39 PM   #1
JayChicago
JayChicago's Avatar
Default Fuel filter placement
Installing a new electric fuel pump and fuel line on a street rod. Pump comes with a course mesh pre-filter/screen. Now the question is, where to install the post-pump fine mesh filter?
Existing filter was is the frame rail near the fire wall, but that is a difficult-to-get-to location on this lowered car. I don't want to see it in the engine compartment. A good, easy-access location would be with the pump, on the cross member in front of the tank.
Any reason why the filter shouldn't be mounted at the back of the car, right ahead of the pump? I will flush the line at the carb one time to clear any particles introduced with the work.
JayChicago is offline   Reply With Quote
Old 12-30-2019, 08:42 PM   #2
Angledrive
Angledrive's Avatar
Default Re: Fuel filter placement
Tank, filter, pump, all in back
Angledrive is offline   Reply With Quote
Old 12-30-2019, 09:29 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
pumps push trough a filter much better than they suck through a filter
Old 12-30-2019, 09:36 PM   #4
50fordcoupeman
50fordcoupeman's Avatar
My avatar is tank-shut off valve-filter-pump.
50fordcoupeman is offline   Reply With Quote
Old 12-31-2019, 08:43 AM   #5
cadillac512
cadillac512's Avatar
Jay, your plan of the fine mesh filter mounted after the pump at the rear of the car is just fine. Although ideally the final filter is right at the carb,this stuff we do requires some departure from "ideal" in order to make everything like we want. Use good plumbing and flush it before putting in service and all will be well.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 12-31-2019, 10:53 AM   #6
JayChicago
JayChicago's Avatar
OK. Thanks for your input, guys.
Old 12-31-2019, 11:03 AM   #7
philipswanson
Wherever you put it, it needs to be encased. There was a video on this forum where a guy had a 40 blow a rear tire and took out the exposed fuel filter, then caught fire and destroyed the car. Mine is exposed in the rear but I plan to encase it. Modern cars always have them protected. A rock could do the same thing.
philipswanson is offline   Reply With Quote
Old 01-01-2020, 07:12 AM   #8
Ritzy1
Ritzy1's Avatar
Here are pictures of how I configured the electric pump/filters on my '48. I still need to add a shutoff valve before the filter/pump. Used Earl's Vapor Guard hose and clamps for the soft lines.
Ritzy1 is offline   Reply With Quote
Old 01-01-2020, 11:40 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
You misread that post about the burned-up '40. The blown tire took-out the fuel FILLER tube, not the fuel filter. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-01-2020, 02:11 PM   #10
oldskool
oldskool's Avatar
Originally Posted by v8coopman View Post
you misread that post about the burned-up '40. The blown tire took-out the fuel filler tube, not the fuel filter. Dd
ouch
oldskool is offline   Reply With Quote
Old 01-01-2020, 02:25 PM   #11
V8 Bob
V8 Bob's Avatar
Electric inline fuel pumps should have a course (+/-100 micron) filter before and a finer +/-40 micron after and close to the engine. There are many billet aluminum reusable filters with cleanable SS filter screens available today that eliminate any worry about glass, plastic or cheap metal construction, and alcohol fuels. My choice is Holley/Earls. They come in several sizes, colors and fitting configurations. A bit pricey, but you never have to replace them, and you can easily keep track of any dirt/foreign material that enters your system.
I use a shut off valve at the tank, then a 100 m filter, pump, and 40 m filter near the carb(s).
V8 Bob is offline   Reply With Quote
Old 01-01-2020, 02:53 PM   #12
philipswanson
I stand corrected, it was the fuel filler tube. But the same thing can easily happen to the filter. On my two 97 T Birds and my 2015 Challenger, the filters are well protected from debris which could cause a fire.
Old 01-01-2020, 07:08 PM   #13
coolcoupe
coolcoupe's Avatar
I really like that arrangement and looks tidy. Good job !!
coolcoupe is offline   Reply With Quote
