08-30-2017, 02:57 PM | #1 |
Model T year id
Try to find out what year this model t is. There's a number stamped in the wood BF31818. The motor number isn't legible. Electric starter, metal seat frame, coil box under dash. I'm thinking it's an 18
08-30-2017, 03:43 PM | #2 |
Re: Model T year id
What type of number is on the title?
08-30-2017, 03:58 PM | #3 |
Re: Model T year id
No title. It came from an old farm and has a Shaw tractor conversion on it last ran in the 60's.
08-30-2017, 04:03 PM | #4 |
Re: Model T year id
08-30-2017, 04:32 PM | #5 |
Re: Model T year id
The cowl is 23 or 24 closed car. There should be a casting date on the same side as the engine number - it will be back & down from the water inlet.
Great looking tractor. Are the front wheels cast iron?
Jack Innes, Brooklin, Ontario |
08-30-2017, 04:47 PM | #6 |
Re: Model T year id
08-30-2017, 06:26 PM | #7 |
Re: Model T year id
The casting no. should be about where the one in the picture is. Some later blocks had a round no. insert. The last no. is the year - this one being 1917.
08-30-2017, 09:20 PM | #8 |
Re: Model T year id
They stopped the casting dates around 1922 or so.
08-30-2017, 11:12 PM | #9 |
Re: Model T year id
That is good information. It explains whey a casting date cannot be found on the tractor.
It is then possible that the engine fits with the cowl at 23/24.
08-31-2017, 01:38 AM | #10 |
Re: Model T year id
I would say it's a late 23 thru early 25 and yes a coupe or sedan.
Cool project. |
09-17-2017, 09:48 PM | #11 |
Re: Model T year id
Sometimes the serial number can be brought back by using a liquid dye penetrant used by piping contractors to detect cracks in piping systems. The slightest indentation will show up.
Just a thought. |
Thread Tools | |
Display Modes | |
