Old 02-20-2017, 03:42 PM   #1
Doug 845
Default 1933 V8 Freeze Plugs????
Please see previous post. The last pic is a duplicate of the third one.
Thanks
Doug 845 is offline   Reply With Quote
Old 02-21-2017, 12:20 PM   #2
B-nut
Default Re: 1933 V8 Freeze Plugs????
Doug, Have come across so many rotten freeze plugs and so much tar like pan sludge in these flatties over the years that I pull the oil pan on every one for a clean out and new freeze plugs. Don't miss this opportunity to clean out your water jackets with some coat hangers or threaded rod and a shop vac.You won't believe the crud on the other side of those freeze plugs.
B-nut is offline   Reply With Quote
Old 02-21-2017, 01:24 PM   #3
DavidG
DavidG's Avatar
With respect, plugs that are securely retained by the attached adjacent oil pan flange aren't exactly "freeze" plugs as noted at the top of the first post.
Old 02-21-2017, 01:35 PM   #4
johnboy34
None of them are "freeze" plugs, they are core plugs to get the core sand out of the casting! Sometimes a few have been lucky they popped when frozen, not very often.
johnboy34 is offline   Reply With Quote
Old 02-21-2017, 01:43 PM   #5
JSeery
JSeery's Avatar
Believe "freeze" plug is a slang term for "core" plug. As far as I know there is no such thing as an actual freeze plug. As stated openings are designed into engine castings to remove the core sand.
