Old 01-24-2017, 09:45 AM   #1
B-nut
Default radius ball felt pad installation in bellhousing.
Working on a 1928 Model A with a later transmission. About to put the rebuilt transmission back in. Is the felt oiler pad in the bell housing held in place by the radius ball bolt locking pin? Seems too thick a pad and there was no pad when I pulled the transmission to go by. Thanks
B-nut is offline   Reply With Quote
Old 01-24-2017, 09:49 AM   #2
P.S.
Default Re: radius ball felt pad installation in bellhousing.
Yes, that is what holds it in.
I cheated and drilled a hole through the pad and put the pin through it. Will probably get scolded for that, but it works.
P.S. is offline   Reply With Quote
Old 01-24-2017, 09:55 AM   #3
JDupuis
JDupuis's Avatar
P.S. Is right. I've done that too. Remember to put a bit of oil or gear oil on it for lubrication of the radius ball. Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 01-24-2017, 10:05 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I also put the pin through the felt on my first one years ago, but most of the time I bend the felt to form a V, then the pin fits the center over the V.
As JD said, put lots of oil in the felt after installing it.
Old 01-24-2017, 10:05 AM   #5
Mitch//pa
It squeezes in tightly under the pin
Old 01-24-2017, 12:16 PM   #6
Tom Endy
Tom Endy's Avatar
The pin holds the felt in place. Photo shows how I position it. The way to install it is to slide the pin in and use a large screw driver to push it down to compress the felt. Tap the pin the rest of the way in with a small hammer.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 01-24-2017, 12:42 PM   #7
P.S.
Tom Endy's word is gospel. Go with that.
Old 01-24-2017, 04:06 PM   #8
Synchro909
Synchro909's Avatar
On one of my cars, the heads of those bolts have receded so far into the housing that the pin does nothing. I have had to make new bolts with higher heads to catch the pin. Where do I get a new bell housing????
I can see that sometime in the future, I will have to drill out the bolt holes and sleeve them get back to standard.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-24-2017, 04:24 PM   #9
CarlG
CarlG's Avatar
Originally Posted by Synchro909 View Post
... Where do I get a new ball housing???? ...
http://www.snydersantiqueauto.com/radius-ball-kit
You may be able to find this down under as well.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-24-2017, 04:24 PM   #10
Tom Wesenberg
On one of my cars, the heads of those bolts have receded so far into the housing that the pin does nothing. I have had to make new bolts with higher heads to catch the pin. Where do I get a new ball housing????
I've had to make small diameter spacers to lift the bolts up. It will outlast me and the owner.
Old 01-24-2017, 04:47 PM   #11
SeaSlugs
SeaSlugs's Avatar
same - some are really bad some not so much - not a great design... vibrations from the road and the fact they are spring loaded act like miniature air hammers just hammering away at the cast iron. Might not be a bad idea to check the tightness of them every 2-4 years...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-24-2017, 04:54 PM   #12
Synchro909
Synchro909's Avatar
Carl, Thanks but I made a typo. Should be "Where do I get a new BELL housing"
Next time the motor is out, I'll have to do something about this.
Old 01-24-2017, 05:47 PM   #13
katy
katy's Avatar
Bell housing or flywheel housing?
Old 01-24-2017, 06:42 PM   #14
100IH
If you notice in post #9. in the upper corner you'll see the felt from Snyders. Thick enough to be for 2 pads. Must be drilled out or somehow modified to not bend the long pin. Good material but a printed note with suggestions would be welcome. Even if the 2 bolts are shimmed up to engage the pin, the felt is way too thick. Tough stuff to cut.
100IH is offline   Reply With Quote
Old 01-24-2017, 07:37 PM   #15
CarlG
CarlG's Avatar
A good used Bell housing or Flywheel Housing, either one could be had at Bert's or Arizona Model A. Just make sure you specify that it has to be crack free. Snyders carries a "new" aluminum Flywheel Housing.
Alaskan A's
Old 01-24-2017, 08:28 PM   #16
TerryO
TerryO's Avatar
About a year ago one of the national club's magazine had an article that said to cut a small coil spring into rings and insert the ring in the recess to raise the bolts to a proper height. I did the repair and it worked very well. I don't remember the size of the spring but I bought it at ACE. It works well because it is thin enough to fit right in the hole without any grinding.
TerryO
TerryO is offline   Reply With Quote
Old 01-24-2017, 10:31 PM   #17
SeaSlugs
SeaSlugs's Avatar
TerryO
I think i used a piece of 1/4-1/8" pipe nipple... or an old bushing out of something... something i had laying around was used and fit nice snug fit on the bolt and no bigger than the diameter of the head.
Old 01-24-2017, 10:37 PM   #18
Synchro909
Synchro909's Avatar
Thanks again, Carl but no chance at either place. We need RHD and I have yet to come across any supplier over there who even knows there is such a thing (except Arizona Model A)
Katy,
The bell housing is where the bolts and felt are located and that's what I need.
Old 01-24-2017, 11:11 PM   #19
Drive Shaft Dave
I sliced the thickness of the felt pad in two, plenty of material to fit tight under the pin.
Drive Shaft Dave is offline   Reply With Quote
Old 01-25-2017, 06:58 AM   #20
B-nut
Thanks for all the helpful comments guys!
