Old 03-26-2015, 01:39 AM   #21
pooch
pooch's Avatar
Default Re: What do you think of this Babbitt
Thank you all for explaining .
I can now peruse the babbitt topics with a little more knowledge and understanding.
pooch is offline   Reply With Quote
Old 03-26-2015, 01:43 AM   #22
dumb person
dumb person's Avatar
So has anyone tried boring an A block to take babbitt inserts like the chevy4's did? Sounds like a good compromise between poured bearings and inserts.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 03-26-2015, 02:19 AM   #23
Kohnke Rebabbitting
I am sorry Mr. Pooch, I just hope I didn't tell you more then I know.
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 03-26-2015, 02:22 AM   #24
Kohnke Rebabbitting
While they both work very well, I don't think there would be any advantage to do so, not if they both can be done well.
Herm.
Old 03-26-2015, 02:33 AM   #25
40 Deluxe
Concerning the comments on the purpose of locking tabs on insert bearings, the new Chrysler V8's do not have locking tabs, they depend on crush fit to hold the insert in place, and I have seen them spin the inserts.
Old 03-26-2015, 09:21 AM   #26
Tom Wesenberg
Tom Wesenberg's Avatar
In 1977 I was working for a MoPar dealership, and a new Dodge van had a very faint engine ticking noise. I pulled the pan and found one of the rod cap bearing notches was cut in the wrong location. So the tab was pressed flat and that bearing was putting pressure against the crankshaft journal. I filed a new notch in the rod cap and installed a new bearing and all was well. Hard to believe they now have dropped the locking tabs.
Old 03-26-2015, 02:48 PM   #27
pooch
pooch's Avatar
Yeh, seems a dumb move to delete the locating notches, ( I won't called them 'locking tabs'), the notches are to locate the inserts not only sideways, but to accurately locate the oil hole.
Any hamfister then could drop the inserts in anywhere and bolt it up.
Old 03-26-2015, 03:29 PM   #28
dumb person
There is an advantage to babbitt shell inserts, no requirement for block heating and complex pouring when the complex pour can be done overseas and out in the middle of nowhere workshops can place the insert years later. (Overcomes the only problem i can find with poured babbitt)
Just when chrysler was having early engine deaths they deleted the locating notch? i can't understand why.
Old 03-26-2015, 03:55 PM   #29
40 Deluxe
Yeah, the other guys at the shop just shook their heads when I read that to them. Soon after a Dodge (Durango, if I remember) came in with a knock-had spun a rod bearing. Was under warranty so off to the dealer for an extended period. Maybe this is a Fiat idea to save a few coins.
Old 03-26-2015, 05:49 PM   #30
372dart
when should Babbitt should peened? warm or cold? Make more than one pour, and peen after each pour? If you did not peen at all, wouldn't the Babbitt fall out line-boring?
372dart is offline   Reply With Quote
Old 03-26-2015, 06:14 PM   #31
hardtimes
hardtimes's Avatar
Originally Posted by Kohnke Rebabbitting View Post
They are N.O.S. Ford Caps!
Herm
Hey Herm,
Great info/instructions and pictures that you are passing on here, thanks for sharing !
You go to front of line for instant ID of nos Ford Caps !
You also posted pics of other caps that made me remember some 'caps' that I had put in a box half century ago. Here they are, main caps. Heavy and think made of bronze/brass (?). Quiz; What are they for/from ?
Never mind the dirt on Babbitt faces , from sitting forever .
hardtimes is offline   Reply With Quote
Old 03-26-2015, 06:54 PM   #32
Kohnke Rebabbitting
Originally Posted by hardtimes View Post
Hey Herm,
I would say 1929 to 1930-31 Chevys Six's?
Herm.
Old 03-26-2015, 07:30 PM   #33
Kohnke Rebabbitting
Mr. Dart, Babbitt should be peened just as soon as you can remove the mold, with out breaking the babbitt lining.
The colder the babbitt gets, the more of a chance you will fracture the babbitt, and the bad thing is you can't see it from the out side.
I use a pneumatic hammer, it covers 100% of the area, a little at a time.
I have seen loose babbitt that you could move in the block, but that is rare.
You may not notice it while align Boring.
Thanks,
Herm.
Old 03-26-2015, 07:54 PM   #34
hardtimes
hardtimes's Avatar
Herm.
Hey Herm,
Wow, you are good at this !
Yup, 1930 chev six ! I had a Lost Angeles engine company ,i.e.- Egge Machine redo my short block and got these back with new in block.
Back in about '60 threw them in a box of other '30 chev parts and remembered them when you commented here.
BTW they have no 'tangs/locator' of sets .
Old 03-26-2015, 10:59 PM   #35
Kohnke Rebabbitting
Hey Herm,
BTW they have no 'tangs/locator' of sets. "END QUOTE"
No they don't Mr. Hardtimes, but what they do have is replaceable upper locating dowel pins in the block for the hole in the top shell to slide over, so the bearings don't spin.
Herm.
Old 03-27-2015, 01:53 PM   #36
Jeff/Illinois
Jeff/Illinois's Avatar
I guess Chrysler just doesn't get it. (Fiat anyway) When they are going broke again because they are building pure junk like they used to, I wonder if the Fed will bail them out again or just cut them loose
Was told by a Dodge mechanic friend just last night that the 9 spd. automatic tranny they are boasting about is now showing signs of failure. Expensive failure.
Jeff/Illinois is offline   Reply With Quote
