Old 08-23-2021, 02:26 PM   #1
kursed30
kursed30's Avatar
Default Well I found my issue from my last post
Well after digging inti the car I finally found the reason it slowly lost power and died last week. After tearing things apart I found that the large timing gear was missing half of its teeth. Now my next question. Do I need to remove the radiator to change out that gear? How big of a task is it to do this?
kursed30 is offline   Reply With Quote
Old 08-23-2021, 02:51 PM   #2
Greg Jones
Greg Jones's Avatar
Default Re: Well I found my issue from my last post
Welcome to the world of Model A timing gears! You can replace the timing gear with the radiator in the car if you are patient, but it sure is easier with the radiator out of the way. You will need to support the front of the engine to remove the timing gear cover. Be sure to remove one bolt each side back at the motor mounts, and loosen the other two a bit to allow the engine to "pivot" as you support the front of the engine.
Greg Jones is offline   Reply With Quote
Old 08-23-2021, 02:55 PM   #3
jg61hawk
Some good pictures here in # 37 #38 posts in thread.
https://www.fordbarn.com/forum/showt...=301829&page=2
jg61hawk is offline   Reply With Quote
Old 08-24-2021, 10:41 AM   #4
katy
katy's Avatar
No you don't.
Old 08-24-2021, 12:26 PM   #5
Bruce of MN
Bruce of MN's Avatar
It sure is easier, though. If you don’t have a helper for the hood, you can rig a rope harness to suspend it with an engine hoist.
Bruce of MN is offline   Reply With Quote
Old 08-24-2021, 12:40 PM   #6
dj
you should also drop the pan and clean out all the parts
so it dont plug the oil pump
DEnnis
dj is offline   Reply With Quote
Old 08-24-2021, 12:58 PM   #7
Mike Peters
Mike Peters's Avatar
https://www.brattons.com/catalogsearch/result/?q=8790
It appears that you have the stock camshaft nut on your car. This camshaft nut wrench is the best way to get the old nut off and back on after replacing the timing gear. The other method involves a cold chisel and hammer, which is NOT the way to do it.
Mike Peters is offline   Reply With Quote
Old 08-24-2021, 01:10 PM   #8
Chris Haynes
Chris Haynes's Avatar
I have replaced the timing gear on the side of the road with nothing but couple of end wrenches, hammer, and screwdriver. Certainly not the correct way but it got me home.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 08-24-2021, 01:37 PM   #9
Benson
Benson's Avatar
Good idea to clean the screen in the oil pump ANY time pan is removed for any reason ...
Benson is offline   Reply With Quote
Old 08-24-2021, 10:58 PM   #10
vern hodgson
I seem to recall replacing a timing gear without a lot of trouble many years ago, but forgot how I did it.
vern hodgson is offline   Reply With Quote
Old 08-25-2021, 11:27 AM   #11
katy
katy's Avatar
Sometimes one has to improvise.
Old 08-25-2021, 02:55 PM   #12
kursed30
kursed30's Avatar
I bought a new gear, new gasket for that inspection window and a new oil pan gasket. Was really hoping to not have to do the whole radiator thing. Will be tearing into it tonight
Old 08-27-2021, 04:11 PM   #13
GPierce
GPierce's Avatar
Changing a timing gear in the Hotel Parking lot, North Conway Grand Hotel during the Mount Washington New Hampshire MAFCA tour, June 2021.
File Type: jpg 7309620A-CC50-4E59-8AB3-8D56B713B388.jpg (107.6 KB, 38 views)
GPierce is offline   Reply With Quote
Thread Tools
Display Modes
