Old 07-17-2021, 07:52 PM   #1
elwood
elwood's Avatar
Default Speedo drive gear
Hey guys, I have a 34 pickup, I replaced the driveshaft seal, bearing race and bearing, easy peasy, knock the seal back in, the race, it hast to snap in to its little nitch, cant go in wrong, bearing goes in, the thrust washer and then the speedo gear and snap ring.
So I posted a pic, you can see there is a lotta room between the speedo gear and the snap ring groove. Thats not right is it ?
elwood is offline   Reply With Quote
Old 07-18-2021, 02:18 AM   #2
Brian
Brian's Avatar
Default Re: Speedo drive gear
Yes, there is end play when assembled
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 07-18-2021, 07:29 AM   #3
elwood
elwood's Avatar
Just doesnt seam correct, thanks
Old 07-18-2021, 12:04 PM   #4
Terry,OH
Terry,OH's Avatar
Your photo does not identify front from rear and is not detailed to see the snap ring. About how much play do you have? Some is OK which has already been pointed out. Do you have the drive shaft gear on correctly?
Old 07-18-2021, 01:09 PM   #5
elwood
elwood's Avatar
Hi Terry, yes I have the speedo gear in correct and in the pic you can see the snap ring grove, I havent put it in yet couse I wasent sure if I had to take it back out..
Old 07-18-2021, 01:30 PM   #6
Mac VP
Mac VP's Avatar
Do you have the B-17290 thrust washer fitted in there between the roller bearing and the speedo gear?
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 07-18-2021, 01:40 PM   #7
deuce lover
deuce lover's Avatar
Here is his pic which I blew up if that helps. I just added a pic of a drive gear I have with the thrust washer.Mine appears different and came with a '33 I had.
deuce lover is offline   Reply With Quote
Old 07-19-2021, 02:25 PM   #8
elwood
elwood's Avatar
Mine looks exactly like yours deuce lover,
Old 07-19-2021, 02:25 PM   #9
elwood
elwood's Avatar
Hi Mac, yes i do
Old 07-19-2021, 03:25 PM   #10
Brian
Brian's Avatar
I 'think' the end play is designed so that as the rear end swings through an arc with suspension travel, even though the actual movement isn't as much up by the clam shell, having the speedo drive gear able to 'float' allows it to remain in mesh at all times with the turtle gear.
Old 07-19-2021, 06:21 PM   #11
Ideucev8
I have just checked an original 34 rear end & torque tube assy that I have, & the speedo drive gear has about 3/16" of movement back & forward on the spline.
It appears to have an even amount of clearance each side when it is lined up with the centre of the cable drive housing.
Phil.
Ideucev8 is offline   Reply With Quote
Old 07-19-2021, 09:49 PM   #12
Brian
Brian's Avatar
Yes, they're designed to have that.
Old 07-20-2021, 03:12 PM   #13
elwood
elwood's Avatar
Thanks everyone ..
